pearldrum's Avatar
Send a message via AIM to pearldrum
speedo cable installation
When you replace the speedometer cable on an early car, do you replace the entire cable, or is it easier to just replace the inner piece (if you even can on a '44)?
'83 arctic silver 944 n/a
Power steering? who needs it!
Old 03-09-2004, 02:59 PM
SoCal Driver's Avatar
Entire cable. Tie a heavy cord to the wheel end of the cable (after it's removed from the spindle) and pull it bach through the fire wall. Use the cord to help pull/direct the new cable.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 03-09-2004, 03:15 PM
pearldrum's Avatar
Okay, thanks!
Old 03-09-2004, 03:16 PM
When I replaced mine I only replaced the inner cable but I checked the sheath visually first to be sure there were no kinks or worn-through spots that would cause the needle to bounce. It works perfectly now. Also, a little graphite down the sheath when installing the cable helps, too.
Old 03-10-2004, 05:59 AM
