Post Finally going to run nitrous
Finally got up the nerve (and saved the cash) to buy a NOS nitrous kit. $435 for 05123, including shipping, which I didn't think was too bad.
In order to prep the fuel delivery system--should I replace the fuel pump? What about the injectors, just have them cleaned and flow-balanced, or can I switch to turbo injectors? (I know Turbo Tim's website says he has some for sale, Tim will those injectors bolt in to an 84 944 fuel rail?).
I remember at least two other people on this board are running nitrous, any install tips would be appreciated. Scott was one of them IIRC.
Anything else I should keep in mind? I'll be running the smallest shot first, and moving cautiously... wish me luck.
Semper Fi
Cpl SH Won
Wpns Co, 2nd Bn, 24th Marines
Old 11-08-2001, 12:15 AM
justin's Avatar
Post
Just make sure you don't over tighten any of the fitting.Just snug them and only put teflon tape or paste on the ones it says too.It will tell you which ones to put teflon on in the instructions.You don't have to change your fuel pump or injectors if they work correctly,but if you would feel better about it go ahead,It won't hurt anything anyway. The kit will come with a fuel pressure safty switch,which scott and I did'nt use because there's no place to put it. Just take your time and be patent....good luck. If you have any questins e-mail.
Drive it like you stole it........Justin
Old 11-08-2001, 09:20 AM
JB2 JB2 is offline
BIG DOG RUN IT....CHECK RENNLIST....CM2(SCW)BARRON USN SEABEE I'M DOING THE SAME THING,HIT ME BACK...jamesbarron74@hotmail.com
MSD 6A,JACOBS WIRES,BOSCH 15V COIL,+4'S,THROTTLE RESPONCE CAM,CUSTOM COLD AIR INTAKE,K&N FILTER,BURSCHE HEADERS,2 1/4 PIPING,HIGH FLOW CAT,FLOWMASTER 3 CHAMBER, TURBO FRONT END,MOMO STEERING WHEEL,STRUT BRACE,KYB'S,MOROSO BATT. BOX AND CUT OFF SWITCH,KENWOOD CD,AUTOMETER TACH AND OIL PRESS GAUGE,SUMMIT DATA RECALL SYSTEM,FALKEN TIRES,EPSILON TWO PIECE RIMS.
Old 11-09-2001, 09:12 PM
rscupper's Avatar
Thumbs down
RICE
Brian
'73RS (almost...)
'84 944 beater
Old 11-10-2001, 04:51 PM
I'm Korean, we like rice
Semper Fi
Cpl SH Won
Semper Fi
Cpl SH Won
84 Porsche 944 with NOS #5123
83 Honda Magna V45
PP-ASEL
Old 11-26-2001, 02:21 PM
fty fty is offline
fty's Avatar
Send a message via AIM to fty
RICE IS NICE -chriz
82' 911 SC"Go Go Green" 87'3.2L,Turbo Brakes,Brake Bias Valve,Fiberglass Front Clip, 16" BBS, Multiple Strut Braces, Re-valved Bilstiens and a few more "Stock" additions. SOLD
04' Audi A4 Avant Quattro S-line- RS6 look alike with half the HP
http://www.eurocompulsion.net
Old 11-26-2001, 05:07 PM
