oil in throttle valve
The inside of My 86 944 throttle valve is covered with oil. Why is
oil being sucked into the throttle valve?
She runs great warm, but idle is getting rough when cold...
Only the idle is bad until warmed up, still drives great cold.
86 944 98k
Old 03-12-2004, 11:08 AM
Feelin' Solexy
Tishabet's Avatar
Is your air filter stock?
Grant
1974 Vespa Rally 200, 1974 Vespa Primavera 125, 1963 Solex 2200, 1938 Buick Special, 2008 Mini Cooper S, 2010 Mazda CX-9, 1986 VW Vanagon Syncro Westfalia, 1989 VW Doka Tristar - in the stable
1989 Porsche 944, 1973 VW Beetle - gone but not forgotten
Old 03-12-2004, 11:11 AM
using K&N air filter
86 944 98k
Old 03-12-2004, 11:17 AM
Feelin' Solexy
Tishabet's Avatar
As in, the K&N filter that you're supposed to oil periodically?
Grant
Old 03-12-2004, 11:30 AM
Sabyre's Avatar
lol.... GO STOCK OR WALK!
"We are the music makers and we are the dreamers of the dreams" -Willy Wonka
Maine 4x4 Club www.maine4x4.org
Old 03-12-2004, 11:46 AM
Yes. maybe been too long since cleaned and oiled it. will that cause rough-cold idle?? also, its not filter oil in throttle valve its mobil 1
86 944 98k
Old 03-12-2004, 11:56 AM
Feelin' Solexy
Tishabet's Avatar
Are we talking like oil residue in there or legit amounts of oil? Except for oil cominf off your aftermarket filter I can't think of any way for oil to get there.
Having never used a K&N myself, how do you know the oil is not filter oil? Is the filter oil a different color or something? Is it possible the PO used normal oil on the filter?
Grant
Old 03-12-2004, 12:18 PM
NEW INFO. The oil is coming from a hose connected to the
plastic oil filler. the hose runs from the oil fill part to the rubber boot that connects to the throttle valve. dont understand why its sucking oil.
think i'm going to need shop manuals for this car!!
86 944 98k
Old 03-12-2004, 12:46 PM
Ok, you need to replace the O-rings that seal the oil filler/mist seperator to the block.
What is happening is the sump is supposed to be under a partial vacuum so that any combustion chamber blow-by gets scavenged and drawn into the intake plenum via that rubber hose.
When the O-rings start to leak the additional air that is drawn into the sump pulls oil vapor into the intake plenum. What is supposed to happen is only the blow-by gets scavenged, and the oil vapor (or mist) collects on the walls of the filler neck and then flows back into the sump.
The O-rings are a dealer part and should run you about $11.00 for the pair. Be sure to check the part numbers because the O-Rings are different sizes and you need one of each.
Cliff Hipsher
'87 944 India Red
'86 951 Kalahari Metallic
Old 03-12-2004, 01:11 PM
88_944's Avatar
LOL!!
My Black 944
My Gaming Forums. Xbox360gen.com
Old 03-12-2004, 02:18 PM
Sabyre's Avatar
nice
Old 03-12-2004, 02:20 PM
