Send a message via AIM to shocker1322
944 A-arms on 924S
Will the A-arms from a 944 fit onto a 924S? Just to make sure I understand this, the 944 arms are forged aluminum while the 924S are stamped steel. Are the antisway bar brackets the same on a 944 as they are on a 951?
Old 03-12-2004, 11:24 PM
SoCal Driver's Avatar
My 944 a-arms are steel.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 03-12-2004, 11:40 PM
pokey's Avatar
Send a message via AIM to pokey
I believe the a arms are aluminum AFTER 85.5 on the 944. I don't know about interchange, but I'm curious as well.
Still looking for the right deal on another P-car
1968 BMW 1600 2 liter
1956 Ford F250
1955 BMW R69
1999 Range Rover Callaway #011 of 220 (Yeah, as in Callaway Corvette...)
Old 03-13-2004, 01:06 AM
Chris_924s's Avatar
EARLY 944 a-arms are stamped steel- replaceable ball joints.
Late 844 have cast aluminum a-arms. You have to drill the ball joints out and rivet or bolt new ones in.
I was under the impression due to the brakes setup (early offset on the 924S)- but late offset wheels- that they are not interchangeable.
someone prove me incorrect.
TENSION YOUR SOCKS!
88 924S Guards/ Black ~ 10 years as a Daily Driver and STILL SMILING!
87 NA Diamond Blue Metallic ~ Gone
Old 03-13-2004, 03:16 AM
Yes you can use the aluminum a-arms. Costs almost $200 each to have them rebuilt; bushings and ball joints. Cost's about $40 each to rebuild the steel arms. I'm keeping my steel arms. I do have a set of aluminum a-arms that need rebuilt if anyone is interested. Also have the trailing arms.
The later off set is in the spindle/strut not the a-arms.
You do not drill out aluminum a-arms to replace the ball joint and it's bushings. You have to scrape a bit of filled epoxy out of the back and take out the snap ring that holds the retaining plate in. It all falls out the bottom.
Old 03-13-2004, 08:46 AM
lousailor's Avatar
Send a message via AIM to lousailor Send a message via Yahoo to lousailor
I also understand that the aluminum a-arms are longer which is why late strut housings have an angled top bushing. the spindles sit on the ball joint thats in the a-arm, and the struts bolt to the back of the spindle. (sounds like the leg bone's connected to the knee bone song)
Louie
'85 (Early) 944 - Beater
'87 924S - Crunch/Rebuild
'76 924 - Long Gone
"If everything seems under control, you're just not going fast enough."
- Mario Andretti
Old 03-13-2004, 09:39 AM
Chris_924s's Avatar
Thanks SoCal.. I didnt do a-arms or ball joints on the late 944- so I couldnt remember to exact setup.
TENSION YOUR SOCKS!
Old 03-13-2004, 04:51 PM
