helowrench's Avatar
78 924 alternator not charging
I have a 78 924 that will not sustain itself running. The alternator has been removed and checked good (under load). the battery also was removed and checked ok. however if you start the car you can watch the voltmeter drop as the car sucks the life out of the battery and dies. Is there a hidden fusible link/fuse/relay I should look for? Is there a wire that commonly goes bad and causes this?
thanks in advance.
Rob
Old 03-17-2004, 10:33 PM
Sabyre's Avatar
Voltage reulator could be bad.
"We are the music makers and we are the dreamers of the dreams" -Willy Wonka
Old 03-18-2004, 05:50 AM
Send a message via AIM to toolboy62 Send a message via Yahoo to toolboy62
If the alternator is similar to the VWs I've worked on (and that's a big assumption so check everything I say) there ought to be a blue wire on the back of the alt. that actually passes through the alt. light on the instrument panel; if that blue wire is disconnected your alt. will not charge *and* the light on the IP will never come on, not a good situation. The alt. needs that feed to energize and start charging...
FWIW I believe the regulator is integral to the alt. so I don't think that is the problem - if the alt. checks good on the bench the reg. should be OK.
nate
1988 944... and a bunch of other cars
Old 03-18-2004, 06:19 AM
bearone2's Avatar
if the alt lite bulb in the ip is bad, the alt won't charge the batt.
87 951, K27/6, Almond Beige, 17" Turbotwist
87 944S, alpine white, 5sp died a violent death
84 944, silver/brown, auto, gone but not forgotten
"may the force be with you"
Old 03-18-2004, 08:53 AM
Smile's Avatar
I've would check for grounding problems or x-wireing somewhere.
/ Porsche 924 Turbo -1979.
Two coloured (original).
http://www.geocities.com/Pipeline/Valley/3424/porsche
Old 03-18-2004, 11:01 AM
nickd's Avatar
Your problem is in the wiring, it's somewhat common. The alt/starter wires run directly beneath the exhaust manifold. The manifold heat leads to increased wire resistance which leads to heat build up in the wires which leads to the wires melting to each other and shorting out/etc.
You'll need to 1st pull the starter wires off and unplug the wiring harness near the battery box. Then pull the alternator out with the wiring attached (keep an eye on how it snakes from the battery box down to the alt/starter).
Then you can either rebuild the harness (not too bad) or buy a new one at the dealer. New harnesses used to be reasonable, I don't know what they're charging for them lately. After replacing, you'll probably find that the starter will spin quicker too.
FYI- the 924 charging system doesn't route the wiring through the dash light like 928's. And if the alt was tested then the regulator is fine (it is internal).
-nick
1991 964 C4 Cabriolet - drop-top pylon destroyer
Old 03-18-2004, 11:35 AM
bearone2's Avatar
before you disect the electrical, does the alt lite come on when the key is turned on?
Old 03-18-2004, 02:41 PM
Mike B's Avatar
Good advice Smile...Bad grounds can cause a host of problems and that's where I would look first.
'86 951
'88 928S4 - the project
Old 03-18-2004, 07:42 PM
bearone2's Avatar
the grounds/wiring can/could be ok, but if the alt lite doesn't come on when the key is turned on THE BATTERY WON'T CHARGE.
Old 03-19-2004, 02:24 PM
bearone2's Avatar
are you a real helo wrench/where?
Old 03-20-2004, 02:52 PM
The discharge light in the dash excites the field of the alternator. Unless the 924 has an alternate 12 volt source other than the dash light to excite the field.
'73.5 911T
'87 944S
'78 928
Old 03-20-2004, 04:15 PM
