Question Good ol' "944 spontaneously dies" issue
Hi Folks:
I'm considering purchasing a 1987 944 N/A. One of the problems it has is the engine spontaneously cutting out. I've done some research on the subject and the 3 most common causes, in order of prevalence, seem to be:
a) Bad DME relay
b) Bad DME unit
c) Bad fuel pressure regulator
From what I've read, if the fuel pressure regulator is bad, the car typically will not start at all, or will start and run for a few seconds and then die. Is that always the case, or is it possible for a 944 with a bad FPR to start up, run fine for a half an hour and then stall?
Also, the owner claims that often the car will usually re-start if he jiggles the big red harness under the steering column. Is it possible there's a loose/corroded connection in this harness or is it a false diagnosis?
Any help would be greatly appreciated. Thanks.
Old 02-29-2004, 08:50 PM
fty fty is offline
fty's Avatar
Send a message via AIM to fty
Check the ignition switch, thats what was the cuase of my problem, make sure the ignition wires are ok too-chris
82' 911 SC"Go Go Green" 87'3.2L,Turbo Brakes,Brake Bias Valve,Fiberglass Front Clip, 16" BBS, Multiple Strut Braces, Re-valved Bilstiens and a few more "Stock" additions. SOLD
04' Audi A4 Avant Quattro S-line- RS6 look alike with half the HP
http://www.eurocompulsion.net
Old 02-29-2004, 09:46 PM
SoCal Driver's Avatar
Re: Good ol' "944 spontaneously dies" issue
Originally posted by Drover
Hi Folks:
As was just mentioned; ignition switch.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 03-01-2004, 06:20 AM
Thanks for the replies.
Thing is, even when it won't start (until said wire is jiggled), it still turns over. If it were a bad ignition switch, wouldn't it not turn over? (forgive the double negative...) How is it the switch can send the signal to fire up the starter but not send the signal to actually start the car? Is it two different connections?
-BP
'87 924S 56K miles
'94 Mazda Protege 125K miles (Daily Driver, RallyCross Beater, POS)
RallyCross: "Eating dirt is a basic motor skill."
Old 03-07-2004, 10:58 AM
Yes. Two different circuits. Two different contacts in the switch.
Old 03-07-2004, 01:44 PM
Thanks for your help folks. I come to find out it's actually a 924S, which suits me just fine. I've put half down on the car. In a week it's mine.
-BP
'87 924S 56K miles
Old 03-07-2004, 06:15 PM
924S is setup basically the same as the early 944's. The DME unit is mounted to the bottom of the steering column. This may be the large harness that the PO is refering to. Think mine is a gray sheath and not red.
Old 03-07-2004, 06:22 PM
Official Sponsor
vital-transform's Avatar
I am in the same issue right now as well PM me and we can compare notes
1988 - 924S Guards red, auto trans
Old 03-07-2004, 08:57 PM
New switch, car stopped dying... but new problems/issues. First, perhaps a bad thermostat? At cruising speed the needle stays way over to the left. When idling it will swing fairly far to the right (about a tick and a half from the red) before the fan kicks in. Also, the oil pressure gauge stays pretty much pegged at 5. At idle maybe it will drop down to 4. ???
-BP
'87 924S 56K miles
Old 03-14-2004, 10:30 PM
Oh, and what the hell is that little orange arrow on my tach? I'd swear it was a shift light but it never lights up even as I swing the tach to redline.
-BP
'87 924S 56K miles
Old 03-14-2004, 10:41 PM
Official Sponsor
CASIS SEE THE OWNERS MANUAL
Old 03-15-2004, 05:35 AM
If only I could find the thing. It was in the glove box when I test drove it. It has since disappeared. I still owe the guy $50 for various administrative things; I think I'll hold it hostage in exchange for the owner's manual.
Old 03-15-2004, 07:01 AM
pokey's Avatar
Send a message via AIM to pokey
If he doesnt coughit up,I'll scan relevant pages from mine and post them.
Still looking for the right deal on another P-car
1968 BMW 1600 2 liter
1956 Ford F250
1955 BMW R69
1999 Range Rover Callaway #011 of 220 (Yeah, as in Callaway Corvette...)
Old 03-15-2004, 12:19 PM
Porsche Crest
Hi Pokey:
Turns out what I thought was the owner's manual was actually the warranty and maintenance book. I'd greatly appreciate it if you could scan the appropriate pages for me.
As for the other two items I mentioned, a) it looks like the thermostat is indeed stuck open. Silly me to think that wouldn't be such a big deal. On my other car, a boffed-up thermostat meant taking off a hose, yanking it out, putting in a new one, and putting the hose back on. Oh, but not on a 944, of course. Nope, looks like you gotta get to the water pump. That chaps my ass because I just had that part of the car torn apart to put in a timing belt, balance shaft belt, and new seals. So now I get to spend the money on labor again to install a $20 part. Yay!
As for the oil pressure, research suggests what I suspected: bad sending unit. Knowing the way things have gone so far, I'll have to tear apart the transmission to get at the oil sending unit.
-BP
'87 924S 56K miles
Old 03-16-2004, 08:23 AM
Feelin' Solexy
Tishabet's Avatar
Hey Drover,
Replacing the thermostat with the pump on the car is difficult but do-able. Do yourself a BIG favor and buy some snap ring plyers before tackling this job.
Grant
In the stable: 1938 Buick Special model 41, 1963 Solex 2200, 1973 Vespa Primavera 125, 1974 Vespa Rally 200, 1986 VW Vanagon Syncro Westfalia, 1989 VW Doka Tristar, 2011 Pursuit 315 OS, 2022 Tesla Y
Gone but not forgotten: 1973 VW Beetle, 1989 Porsche 944, 2008 R56 Mini Cooper S
Old 03-16-2004, 08:37 AM
Feelin' Solexy
Tishabet's Avatar
heres a link to the thermostat replacement procedure from Clark's Garage.
Grant
Old 03-16-2004, 08:43 AM
Official Sponsor
the pressure sender is easy if you have a lift otherwise you will need to lay on the ground and slide underneath the car for access...
I think there are 2 size thermostats one for the old style WP and one for the new (different spacers?) is anybody an expert on this?
Old 03-16-2004, 08:59 AM
Tshabet:
I appreciate the links and the advice, but I have neither the tools, the space nor the mechanical inclination to do this myself. It goes into the shop.
Meanwhile, what are the potential consequences of having it run cool all the time? The temp is fine for around-town puttering; it's not until I do some highway cruising that it goes waaay down. Should I avoid highway trips until the thermostat is fixed?
-BP
'87 924S 56K miles
Old 03-16-2004, 09:39 AM
pokey's Avatar
On a lot of cars, running cold,or without a thermostat, will cause it to ru somewhat rich.
1956 Ford F250
1955 BMW R69
Old 03-16-2004, 04:46 PM
gtroth's Avatar
As I remember it, CASIS light means the engine can operate at higher efficiency with the same performance (same acceleration) if you upshift. I seem to remember it might mean other things at different times. I'd go get my manual but my car is a few blocks from here at the bottom of a hill unable to climb it in the snow. Nice walk home, though.
1995 993C4 guards red
1988 944S alpine white
Old 03-16-2004, 05:01 PM
