fast924S's Avatar
Send a message via AIM to fast924S
Where do all the relays go??
Im in the works of trying to get my parts late 85 944 to turn over. I only have one really big problem, When Cooler sold me the car he pulled all the relays in the engine bay, Does anyone have some pics off the relays and there locations. I have most of them but I dont know where they go. Please help
1986 951, Stock for now.
]87 924S Gaurds red- SOLD after 11 years of ownership
Old 03-18-2004, 08:34 PM
Used & Abused
1 - 944.615.115.00 - Ac Compressor
2 - na+T 85-86 - 944.615.117.02 - Sunroof
2 - 88 - 944.615.113.01 - alarm
3 - 87T - 951.618.149.00 - Turbo water pump
4 - 87-88 - 928.615.124.01 - ABS
5 - 86-88 - 944.615.117.02 - sunroof
5 - 86T - 951.618.149.00 - Turbo water pump
6 - 88T - 951.618.149.00 - Turbo Pump
7 - 141.951.253.B - Fog Light
8 - 944.615.119.00 - High Beam
9 - 141.951.253.B - Horn
10 - 928.615.111.01 - X Terminal?
11 - 928.615.111.00 - Headlight wqasher
12 - 928.618.102.03 - Warning Buzzer
13 - 944.610.183.06 - Bridge Adapter
14 - 944.615.116.00 - Window
16 - 928.615.101.01 - Intermittent Wipers
17 - 944.615.119.00 - AC blower
18 - 141.951.253.B - Terminal 15 relay
19 - 928.615.203.00 - Rear defroster / fuse tester
20 - 111.953.227.D - flasher
21 - 944.615.227.00 - DME
22 - 85-86 - 944.615.104.01 - Radiator fan
22 - 87-88 - 944.615.104.03 - Radiator fan
There's a note that says relays may not correspond w/ locations prior to 9/86 switches are 4 & 20
after 9/86 some are 18 & 19 empty, 4 & 20, 5 & 21, 6 or 3 & 22
God I wish my scanner worked!
Hope it helps
83 - 944, daily driver
62 - VW Karmann Ghia, never moving restoration
"Oh Bother," said Pooh, as he chambered another round.
Old 03-19-2004, 12:49 AM
^That is the worst god damn sketch ive EVER seen...
Ahahahahaha..
http://944-world.com/earlyfusepanel.html
Old 03-19-2004, 01:09 AM
fast924S's Avatar
Thanx that is waht I was looking for than IDONTKNOW
Old 03-19-2004, 01:51 PM
Feelin' Solexy
Tishabet's Avatar
Ahahahahaha..
I thought it was pretty helpful.
But then again, I'm not a stupid *******.
Grant
In the stable: 1938 Buick Special model 41, 1963 Solex 2200, 1973 Vespa Primavera 125, 1974 Vespa Rally 200, 1986 VW Vanagon Syncro Westfalia, 1989 VW Doka Tristar, 2011 Pursuit 315 OS, 2022 Tesla Y
Gone but not forgotten: 1973 VW Beetle, 1989 Porsche 944, 2008 R56 Mini Cooper S
Old 03-19-2004, 02:00 PM
Send a message via AIM to latunluvr Send a message via Yahoo to latunluvr
OK, in regards to the relays, does anyone know how to diagnose the DME relay and see whether or not it's bad? It's listed above as number 21. Porsche part number 944.615.227.00.
92' 968
86' 951
Old 03-19-2004, 02:08 PM
FLA944's Avatar
Send a message via AIM to FLA944 Send a message via Yahoo to FLA944
Latunlovr,
[originally posted by SoCal] As you have an 86 with the better fuse/relay block you could have just jumped between the proper contacts on the plug for the DME relay and found out if the relay was bad. Still better to have a known good as a spare.
'83 944 "Guards Red"
New Everything (seems like)
16" 968 Wheels
has never left garage (yet)
Old 03-19-2004, 05:03 PM
I found out it was bad but making a 3 way jumper and put the jumper in 87, 87b, and 30. The car started right up! Just did it 10 minutes ago. Awesome. I no longer have the 86 951. I've got a 92 968 Tiptronic now. I pulled the DME relay apart just a couple of minutes ago and remelted/added some solder at every solder point inside of the relay. I popped the relay back into the car and she started right up! Between the 3 way jumper and resoldering the DME/Fuel Pump relay points, the car starts right up after sitting for nearly 3 years! What a deal!
92' 968
86' 951
Old 03-19-2004, 05:32 PM
pearldrum's Avatar
Send a message via AIM to pearldrum
Nice...mine sat for 6.5 years and I had to replace almost it seemed EVERYTHING on the car to get it to run.
'83 arctic silver 944 n/a
Power steering? who needs it!
Old 03-19-2004, 07:06 PM
