-   -   a/c & heater control lights (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/154511-c-heater-control-lights.html)
scrambled2k3 03-20-2004 08:43 PM
I've been replacing some of the lights in the car with some blue led's and now my air/heater lights look retarded cause they are still glowing white. I tried taking the control unit out to get to the light bulbs, but they seem pretty impossible to get to. Does anybody know how i can get to these lights? They can't be impossible cause what if one burns out and you need to replace it? Thanks in advance.
Zero10 03-20-2004 11:02 PM
They are not supposed to be replacable.
There's the bad news.
I wouldn't put blue LED's everywhere... mix em up a bit =)
I considered installing many LED's in my dash, replacing all the burned out bulbs. But, keep in mind some of the bulbs are meant to shine sideways.
Just start taking the control apart, and you'll see how they are installed.
If they are soldered in, then they weren't meant to be replaced, if not, then they were =)
Just remember your resistors. 1/4W resistors may be a little tough to get in there though.
scrambled2k3 03-21-2004 02:46 PM
I'm good with sortering and such, so if I can get to the led's on the circuit boards, they shouldn't be a problem. I just can't get the stupid plastic casing off from the boards.
