-   -   ground on a 3 wire O2 sensor ???? (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/155001-ground-3-wire-o2-sensor.html)
Don 944 LA 03-23-2004 09:44 PM
Probably a stupid question but am I correct ????
on a 3 wire O2 sensor (wire-1) heater ; (wire-2) signal ; (wire-3) common ground for heater and signal.
The reason I ask is does a 3 wire use the exhaust system as the ground for the signal to the DME.
If so, is there any ground spot for the exhaust.
Thanks again
1984/85 944na
Kalahari Beige (gold) exterior / Black interior
Los Angeles / San Diego
Lookin for ideas etc...
http://www.carquip.com/parts/graphix/944.jpg
awilson40 03-24-2004 04:59 AM
the one wire is the O2 sig. Block is ground.
The other 2 wires are for the heater only.
It doesnt matter which is power or which is ground.
Porsche944 03-24-2004 06:54 AM
A 3-wire sensor uses chassis ground through the exhaust system.
On your car there should be a rectangular two-wire "bullet" connector with one male, and one female "pole" somewhere in the vacinity of the O2 sensor signal connector. This connector is for the heater wires on the sensor.
