-   -   Help with steering rattles in column (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/155061-help-steering-rattles-column.html)
andnew 03-24-2004 09:56 AM
83 N/A with manual steering. Car is running good and now I'm down to the I'll get around tuit's :-)
I am getting a pretty jarring rattle through the steering column and I see the bearing where it goes through the firewall, looks pretty nasty, so I plan to clean and repack this. I know all the front end components are perfect with less than 4k on them. (And yes SoCal, I did retension the belts).
Anyone have an exploded pic of the columm internals? I'm assuming there must be more bearings that need attention.
Thanks!
TCMdocs944 03-24-2004 10:01 AM
I need this too. I have the same trouble to the point that my horn does not "contact" unless I lift up on the steering wheel a little. I think there is one bearing inside the upper column and one at the fire wall.
Check for a crack in the firewall as well. I have seen these in a few earlies.
andnew 03-24-2004 10:06 AM
I'll keep you posted, I'm going to tackle this anyway. It's raining buckets and I've got the day off. This is the last one of the "This pisses me off" things I want to get fixed.
andnew 03-24-2004 11:03 AM
Ha! problem solved. The bearing behind the TS and wiper switches was completely dry, literally the balls were rattling over sharp irregularities. I packed it by hand and the noises are gone. Mine didn't have excessive play, just the rattles.
TCMdocs944 03-24-2004 11:49 AM
I think that bearing is gone in mine....you suck........J/K
