Anybody using wider skins on rear?
Since the rear wheels are slightly wider (and need replaced this summer) po had 4 same size on car. Anybody going wider in the back -15" Fuchs? I put oem size Falcon Zeix on the front already.
TIA
Jerry 92 Range Rover 83 944 SOLD 92 Subaru 97 Boxster |
How wide are the wheels?
Here's my setup: (Note I have 16' wheels, not 15's) 225-50/16 on 7Jx16 front 245-45/16 on 8Jx16 rear. -Z.
2010 Cayman S - 12-2020 - 2014 MINI Cooper S Coupe - 05-17 - 05-21 1989 944S2 - 06-01 - 01-14 Carpe Viam. <>< |
Writer/Teacher
i don't know if it would benefit getting wider wheels for the NA944... not a whole lot of torque being laid down in the rear.
That being said, I would love to get a 205/50/15 front/ 225/50/15 rear setup on my car if I could find a good tire that runs in both those sizes
Current Stable: Black 07 Porsche 987 Cayman S: Long-Tube Headers; FabSpeed Exhaust; VividRacing ECU Tune; IPD Plenum; 997GT3 Throttle Body. Blue 1983 Porsche 928S. 1985.5 Porsche 944 Rat Rod. 2011 Acura MDX. 2008 Mazda 3. Gone But Not Forgotten:Garnet Red 86 Porsche 951("The Purple Pig"). Alpine White 83 Porsche 944 ("Alpine Wolf"). Guards Red 84 Porsche 944. |
If you want to go much wider than stock you are probably going to need a wider rim, I have had 10" and 9' wide rear on the 944 (87 ) ..currently have a 17x8 front and 17x9 rear. I am not sure what the stock rear side is on the 15" wheels, I believe it is 215-60-15, you could put a 225-50-15 wich is slightly wider..much more you would have to change the rim width.
autowerks9 PCA SINCE 1991, REISENTOTER 1982 EURO 928S 320HP MEDIORMETALIC/BURG. 1987 944S- GT3 BODY CONVErSION RED/BLACK( sold ) 2003 MERCEDES E500 Sport "Einfarbig" |
There are 3 main brands that have these 2 tire sizes in both a 205-50-15 and a 225-50-15
1. B.F. GOODRICH SPEED ..euro ta ( new gen )........$95.00...............H rated ..g force t/a drag...............$125.95............Z rated ..euro ta............................$125.95............H rated .. comp t/a drag rad..........$135.95 .. g force t/a zr..................$158.95.............Y rated 2. DUNLOP ..G.t qualifier......................$65.95............. ...T rated ..dunlop sport 8000...........$118.95..............Z rated .. sport 9000......................$161.95..............z rated 3. HANKOOK ..ventus hr11 h405.............$72.95...............H rated ..ventrus k102.....................$76.95..............V rated 4. REPUBLIC ( goodyear product/kelly springfield) .. ultra hp 4 directional tr......$65.95.............T rated priceds are suggested retail through ford tire network, usally comperable to tire rack when you add shipping..
Writer/Teacher
Yokahama AVS ES100 seems like a good deal
205/50/15 $74 225/50/15 $89 Does anyone know if I would save money by purchasing them from Tire Rack and then having my mechanic install them? Or should I just do Town Fair Tire and get it over with?
I would check the ratings on the tires for treadlife, temp and traction.
most of the yoca's i have seen have a very soft compund and do not last as long as you would expect on day to day driving.
entertaining the idea
I have 205 50 16s on 7x16 Fuchs in front and 225 45 16s on 8x16 in the rear. The tires are Dunlop. They came with the the car when I bought it.
I've had no problems with them except that traction is lacking in snow. Other than that, I think they are great tires.
There are some who call me... 'Tim'. a well set-up 1983 Guards Red 944 |
What would Darth Vader do
I think that Costco may have a facility in Ct. If so, they have reasonable prices, which include mounting and balancing and a vast selection
1983 944 (2002 to now) 3-924's (Sold) 1967-912 (Traded) NEVER put a used water pump in your car... |
I'd stay away from Dunlops, Hancooks, Kumhos, Repbulics (?), and Falkens.
I had Dunlops and they weren't very good, and the other tire companies I list are what they consider third-tier companies. You know the old saying, "You get what you pay for." Definately true in the tire business. Just my $0.42, -Zoltan.
I had a very good experience with Kuhmos on my wife's Volvo 850R. Excellent treadware for a Z rated tire and they were relatively quiet. Those Yoko AVS ES100s that were mentioned are supposed to be very good, affordable performance tires too.
Check out the ratings and comments on TireRack.com.
Matt '90 Porsche 944S2 Cabrio Baltic Blue Metallic/Linen LSD 2002 Yamaha FZ1 |
Z-man, I agree to a point. There are very few car parts that are universally used that have seen the advances that tires have. New compounds and tread designs offer dramatic improvements over what was top of the line in the past. If you are buying the best tires you can, you are getting a superior product.
From what I understand buying an off brand is not necessarily a bad thing though. There are very few actual tire manufacturers, and often times an off brand is simply marketing what was 2 or 3 years ago a top of the line compound and tread design. I'm not defending Kuhmos or Dunlops, just the idea that you can buy an off brand tire and get a decent quality product. (Just don't expect them to be as good on the autocross course as a current top of the line model.)
'86na, 5-spd, turbo front brakes, bad paint, poor turbo nose bolt-on, early sunroof switch set-up that doesn't work. Malo periculosam, libertatem quam quietam servitutem. |
Geez, lots of input. I'll look to see if Falcons make the slightly larger size for the rear. I WILL BE honest by saying that appearance is what I want. I don't autoX and my driving habits will be thru the summer around town a little and definately into CA and Tahoe.
I'll also admit that I am not too familiar with Falcons but in my experience (worked at shop for 8 years) off brands will be an off-shoot from a major tire maker with a reputable history (minus the Exploder!) The Falcons came with a good warranty 1 yr free replacement and pro-rate beyond 1 year. This car is quick but I don't want to drop the clutch and attempt to spin the tires all the time. And this is not the daily driver.
Yoko ES 100 is good, so is the Dunlop FM901. I'm running some Bridgestone Potenza RE950 (I believe I paid ~$78 a tire) and I LOVE them. They're great!. But running wider tires in the back or stickier tires in the back will actually make the car handle worse. It will contribute to creating more understeer.
Z-man, what's ur problem with Falken? The Azenis ST215 is an AWESOME tire!
95 240sx-track slut w/ too much done to list 87 944 n/a-old "toy" that broke too much |
least common denominator
I have 15 inch cookie cutters with 215 front 225 back yoko's. it is VERY rare but if I really get on it I can chirp the tires. They handle great although I now wish I had gone with 225's all around.
YMMV
Gary Fisher 29er 2019 Kia Stinger 2.0t gone ![]() 1995 Miata Sold 1984 944 Sold ![]() I am not lost for I know where I am, however where I am is lost. - Winnie the poo. |
I think there may be some understeer issues
"We are the music makers and we are the dreamers of the dreams" -Willy Wonka |
'86 951 '88 928S4 - the project |
Stock size on my S2 Cabrio is 225/50-16 (rear) and 205/55/-16 (front). I don't auto-x or anything like that. My Dunlops Sport 8000s seem like decent rubber. I'm going to 255/40-17 (rear) and 205/50-17 (front), so I'm going to be running a little wider in the rear than currently. It should reduce the current tendency to kick out the rear when I'm getting on it in a corner, but may contribute to more understeer. I'll give you a report after I get them installed and drive it a little. Of course, I'm going to Michelins, so differences may be compounded by going to a different tire.
BEFORE ANYONE BUYS NEW TIRES
CHECK OUT THIS LINK http://www.tirerack.com/tires/surveyresults/index.jsp It's a tirerack link, but it is often overlooked. This is the HOLY GRAIL of tire test information. I recommend Ultra High Performance or the Max Performance test data, but there are some very fine tires in the other categories too, including the Bridgestone RE 950 that I put on my wife's Turbo Volvo. This page is a heck of a lot better than "shopping brand names" or "shopping price", it has data we can use. happy reading BTW I have a set of Firehawk SZ50 EPs on my 944, one size larger than recommended (perhaps a too tall profile for the 944 but looking good and fitting the car), and the Bridgestone RE 730 on the 928, both of which are fine tires. I think I'll try the Firehawks on the 928 next time. Regards, P
1983 928S 5-speed, 1984 944, 1990 944S2 Cabriolet My other car is a Chris Craft Commander http://www.chriscraftcommander.com |
Although I haven't had Michelins on my cars for a long time, I would still recommend them as well, given my past experience and what I have heard others say about that brand. Quote:
Truthfully, I haven't had first hand (or second hand) experience with that brand, but I have spoken to some tire distributors regarding third tier manufacturers of tires. They tend to shy away from these brands due to not as good overall quality, performance, and wear. Again, this is just In My Humble Opinion. -Zoltan.
