Testing (44s igntion coil
Hi,
I have a 1987 944S. I pulled the coil to check the resisitance according to my Haynes manual.
The primary resistance between 1 and 15 is .6 ohms (That is OK).
I removed the rubber plug that covers lead 4 and checked the resistance between 1 & 4 and I get nothing. If I check between 1 and the center output of the coil (where it goes to the distributor) I get 5.6K ohms which is what I should get between 1 and 4.
My question is simple.
Is lead 4 the same as the output from the coil?
I know I can go pick up another coil fairly cheap but I want to know if this one is really bad or what?
Thanks!
Old 03-30-2004, 07:59 AM
fast924S's Avatar
Send a message via AIM to fast924S
bump
1986 951, Stock for now.
]87 924S Gaurds red- SOLD after 11 years of ownership
Old 03-30-2004, 03:05 PM
SoCal Driver's Avatar
944S also has an ignition modual. A Porche compacitance discharge unit. If you are having problems with your spark then this has to be checked too.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 03-30-2004, 04:28 PM
