NEED A.S.A.P : Turbo strut mount
I need part number 951.343.018.02 or it has been superceded by part number 03 then 04.
I actually just need the studs on it. So if you have an old worn suspension mount......... the one at the top at the strut. I need A.S.A.P. Let me know what you want for it and I will pay for UPS next day as well........ THANKS!
Alex - PCA Polar Region - Boxster Muncher 86' 944 Turbo - Megasquirt - 326 rwhp/340lbft @ 18 psi SOLD www.edmontonhomelife.com www.edmontonrealestate.ws |
Will work for parts
I have a pair of late model strut mounts. It is not the same as the 86 turbo but is the newer version. If you just need the studs, they should be the same, right?
-Greg
'88 944 240,100 miles -race car '05 Boxster 110,000 - Daily Driver '74 911 Targa - long term project |
If it has a 951. part number it will work........
I am pretty sure the studs are spot welded in 3 places on the ones you have....... the 951 on 87> the studs can be replaced easily.
Greg can you take a pic of both sides of the mount ? Just in case.....
Thanks Alex P.S ....someone has to have an old mount with part number 951.343.018.02 or 03 or 04
Will work for parts
Greg those may work !!..............
Compare them to mine...... The studs should pop right off...........and they have little grooves where they attach on the mount! Crossing my fingers and toes.... How much you want for them? Are you looking for any parts? I may have what you are looking for........ PM me. ![]()
What's your hurry? Edmonton thawed out?
______________________ Cars |
CHeck the part number greg........ its on the underside of the mount......
THANKS AGAIN!!!
Go back and weld some aluminum you hack ........... hehehe
I think you mean "JB Weld some aluminum, you hack".
Greg .... THANKS!
Received the mounts today! ..... exactly what I was looking for.... Thanks for popping a few studs off...... Its an interesting setup porsche used isn't it. I will be pulling those handles soon. When I have them I will send them out. Thanks again! Alex
