Radio Removal on 944?
How do you remove the radio (Porsche factory CD2) from a 90 944? Any special tools needed? Thanks.
Old 04-06-2004, 10:14 AM
Chris_924s's Avatar
There is a special tool, I believe FORD uses the same one.
But.. You can remove it if you find 2 pieces of wire (coat hanger like) and push into all four holes at once, releasing the locking tabs. The head unit should pull right out after that.
TENSION YOUR SOCKS!
88 924S Guards/ Black ~ 10 years as a Daily Driver and STILL SMILING!
87 NA Diamond Blue Metallic ~ Gone
Old 04-06-2004, 10:49 AM
entertaining the idea
UconnTim97's Avatar
I used a bent coat hanger like Chris said...worked fine.
There are some who call me... 'Tim'.
a well set-up 1983 Guards Red 944
Old 04-06-2004, 02:12 PM
gtroth's Avatar
I replaced my radio with a new Blau, and it came with the u-shaped tools. The tools had hooks on the end so that when you insert them, you could pull the radio out with the tools. Handy, but coat hanger wire should work too.
1995 993C4 guards red
1988 944S alpine white
Old 04-06-2004, 04:52 PM
