TCMdocs944's Avatar
Question Can spacers be safely stacked?
I am trying to figure out the best/most economical way to go with spacing out my new wheels.
Rear could use 1.5 - 2" total and front 3/4 to 1.5
Can I double stack rear factory spacers by just adding longer lugs or is this a very stupid and dangerous idea?
or
Should I buy rear 1.5-2" spacers and move the others to the front, with there lugs?
83 944 white w/Boxster wheels
Planned mods- custom leather interior, 968 antenna, soundsystem, 968 style rockers, clear sidemarkers
Old 04-06-2004, 04:34 PM
I wouldnt stack them in you can avoid it.
Old 04-06-2004, 05:14 PM
TCMdocs944's Avatar
Kinda thought that.
How about the rear spacers on the front of an early
Old 04-06-2004, 05:39 PM
justin's Avatar
As long as your studs are long enough, I'm sure Pelican sells them, rule of thumb is when you screw the lug nut on, you need at LEAST 9 complete revolutions.
Texas hosts the 928 Owner’s Club OCIC in 2009
www.928ocicdfw09.com
1980 928 5 speed and a few mods..........
928 OC member
PCA member
Old 04-07-2004, 12:21 AM
TCMdocs944's Avatar
Looks like I will be doing a lot of measuring this week.
Anyone ever stacked a little extra on the rear of an early? How much can you go up to?
(I know, I know, go out to my damn car and turn the lugs to check right.)
Old 04-07-2004, 08:35 AM
adrian jaye's Avatar
"the wheels on the bus , go round and round, round & round, round & round
the wheels on the bus , go round and round, all day long"
untill they came off, cos someone had put spacers on them, then the bus crashed and burned
The fear of God is the begining of wisdom <><
NotJustPorsche
Subscribe: notjustporsche-subscribe@yahoogroups.com
Old 04-08-2004, 02:46 AM
bertman's Avatar
Re stacking a little extra in the rear... iirc, when using OE rear spacer you can add only about 7mm (.275 inch) more spacer before needing longer lugs.
bertman
84 944 Original Owner
65 Plymouth Satellite
08 Mercedes-Benz E 350 Sport
Old 04-08-2004, 06:07 AM
TCMdocs944's Avatar
Thanks Bertm.
Don't think that will quite be enough....very good to know that option though.
Old 04-08-2004, 02:49 PM
