Does the 924S rear wheels bearings fit into the 944 na????
thatīs it........do they fit?????
Step on it!!!! |
also the 924S emergency brakes parts, shoes, etc.....
Step on it!!!! |
Used & Abused
for the rear wheel bearings, 85.5+ 944 and turbo bearings and such are the same.
for emergency brakes, everything from 78-88 are the same with the exception of the lower spring is different on early 944's
83 - 944, daily driver 62 - VW Karmann Ghia, never moving restoration "Oh Bother," said Pooh, as he chambered another round. |
924S is the same as the early 944's. 83 to 85.1 model years.
Hugh - So Cal 83 944 Driver Person NOT a 'real' Porsche -- Its Better!!!! When was the last time you changed your timing and balance belts and/or cam chain and tensioner? New Users please add your car's year and model to your signature line! Never break more than you fix! |
Used & Abused
I checked my books and the 924S uses later components.
![]() Took me a while to figure that much out, so no laughing.
idontknow does know, the 924S uses the later 85.5 and up aluminum trailing arms, the fronts are a different story, they're steel
ok......but I only need the 924S rear bearings............my car itīs a 1986 944 NA and the 924S itīs from 1984 I think...
And w about the emergency brakes shoes????
Step on it!!!! |
ow..........and the front lights lifter engine is it the same???? or not????????
Step on it!!!! |
also for the rear watch.......is it the same or not?
Step on it!!!! |
you'll typically only find '87 and '88 924S's
the headlight motors are the same but the rear "hatches" are different the 924S has a smaller spoiler
for the offset
remember, the 924S doesn't have the fender flares that the 944 does
I have 4 924S's, I know.
thanks...........you are right yhe 924S itīs 87 not 84......sorry...........then they fit..............the emergency brakes parts, the rear wheels bearings, and the front lights lifter engine.....
thanks for the help
Step on it!!!! |
SoCal: why did you delete this post?
quote: -------------------------------------------------------------------------------- Originally posted by highboost951 idontknow does know, the 924S uses the later 85.5 and up aluminum trailing arms, the fronts are a different story, they're steel -------------------------------------------------------------------------------- SoCal Driver wrote: Really? Then why are the stub axles and the hubs the same part numbers as the early 944's? Notice the later 944's have a different part number for these items. |
Lost in translation: "front lights lifter engine".
Was blurry eyed, just awake and didn't read the parts listings correctly.
Why did you repost it?
Do you have a problem with that?
