TPS sensor
does anyone know what each wire is for on the throttle body sensor, I have a 1987 924S, IF you could tell me the color of the wire and what it does it would be very helpfull, Im trying to find out if there is a 5 volt reference wire. Thanx
Throttle position switch(s). Two. One for idle and one for wide open throttle.
N.C. / Idle Connector pin 1 white/black to DME pin 2 Connector pin 2 brown to ground at DME N.O. / WOT Connector pin 3 white to DME pin 3 Don't know what voltage they use. |
| All times are GMT -8. The time now is 02:40 PM. |
