Non-performing Pwr Window
OK guys. Pass side window has been working intermittently. Now its down and won't go up. I have rebuilt all of the switches. Sanded all of the contacts. it's not a fuse or a motor problem. I had current to the conectors going to the motor this weekend but now its gone. Anything else to check thats not a wiring issue? That's out of my league.
West Chester, OH |
Check the Fuse
I did. All of the fuses look good. Does anyone have a fuse diagram. I will replace it just to be sure.
After you check the fuses then start backing down the wiring harness from the window motor to see where you can find current.
Even though you have rebuilt the switches sometimes the rebuild doesn't last for long (though a couple days is sort of short) so try changing out the switch with a good one to eliminate that as an issue. The next problem area is where the wiring goes through the rubber accordion tube between the door and a-pillar. The wiring can fracture inside the tube or within a few inches of there from flexing. And it may just fracture the wire core while the insulation looks OK. If it is this then you will see intermittent failure until it finally goes for good. |
