Burn the fire.
A big thank you..
To those that came to help out with my little 924!
![]() We got it running for a good 5 mins toda (even though it idled horribly rough and at low RPMs)... BUT! It was going on its own for 5 mins... We shut it down after then because the cooling fanst are not hooked up yet. So, Hugh, Don, thanks for showing up! Unfortunately Scottmandue was horribly ill, and Gordon had to work as usual *cough*flake*cough* ![]() Maybe next time we'll get 4 for 4... or more. heh. I definitly feel that this car will be rock solid in a little while, especially with the help of the PAP 924/944/968 community
[x] Working | [_] Broken: 2017 Victory Octane [x] Working | [_] Broken: 2005 Ram 1500 SLT w/5.7L Hemi "Drive it like you stole it." |
What would Darth Vader do
I distinctly remember telling you that 10:00 on a sunday morning was too early.. I need my beauty sleep ya know..
Work?? whats that?
1983 944 (2002 to now) 3-924's (Sold) 1967-912 (Traded) NEVER put a used water pump in your car... |
Don't need to get so Sally Fields about it.
I just stood around and nodded my head a few times.
Hugh - So Cal 83 944 Driver Person NOT a 'real' Porsche -- Its Better!!!! When was the last time you changed your timing and balance belts and/or cam chain and tensioner? New Users please add your car's year and model to your signature line! Never break more than you fix! |
Burn the fire.
Yeah hugh but you shoulda been there when we were trying to troubleshoot my fuel distributor and why the damned thing wouldnt hold an idle on its own.
I told ya... Put a sock as counterweight !!!!
naw, but seriously, It was an educatioin for me. I had not even seen a 924 before. We must do it again... I just wish I had a place to work on mine. Oh, and Hugh, 9v off the AFS = early DME Don
944 85.0 Kalahari Beige -- Dead/Gone/NotForgotten (Ran Like a Raped Banshee) 944 85.5 Guards Red Current Stable 944 83 Kalahari Beige manual rack, short 5th gear951 86 Guards Red, pristine TurboYou must not anger the Porsche Gods - you MUST leave one small item unrepaired, lest the Stuttgartians smite thine car with bad Ju-Ju-AF Juvat |
Grab the part number off of the DME and check Wilks site. May just be one of those transion DME's with the socket.
Anyway, I found that I had to turn the AFM spring 4 notches (left) to get the proper .85 v off the O2 sensor. I think the PO's mechanic changed it to run better. Thanks to everyone for the help in this matter. Don
What brand/model volt meter are you using?
least common denominator
I ended up taking a sick day yesterday off from work and still feel like s**t... But what the heck today I figued if I'm going to be sick I might as well come in to work and get paid to feel like crap.
Let's do it again, It's been over a year since I have had a chance to pick hugh's brain. Just remeber I work Saturdays so I'm can only come out to play on Sunday/Monday... and I'm with Gordon 10am on a Sunday!
Gary Fisher 29er 2019 Kia Stinger 2.0t gone ![]() 1995 Miata Sold 1984 944 Sold ![]() I am not lost for I know where I am, however where I am is lost. - Winnie the poo. |
I had to go to San Bernardino on Monday..And even at 10:00 am it was HOT. In rethinking all this and maybe earlier is better..Say 5:00 AM...??
Have to say you have a nice view of the Pacific from your apartment Gordon. About a little over a mile right down that little canyon. I can see where you are spoiled when it comes to any temp over 68 maybe 74 degrees.
Did you ever find the owners manual for your long gone 924?
Burn the fire.
So, gordon, if i follow your example with 924 care, i can get it not-running again in like ... what ... a week?
![]() Good news, ran the car for about half an hour this evening. Still some idling problems, probably due to fuel injectors. My vacuum advance is working well. I'm also going to clean the injectors real good this weekend and see if that brings it up to a good 850-900 rpm idle. This evening it fired right up, and granted with one out of two fans running it can get pretty warm pretty quick, idles right now at about 600-700.
brando, have you checked the injector pattern?
Burn the fire.
You mean the spray pattern?
The one that was cleaned (heh) sprays real nice and everything. The other 3... not so sure. Also going to clean the injector on the cold-start valve.
