-   -   Chain Tensioner on 944S rebuild vs. replace (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/160266-chain-tensioner-944s-rebuild-vs-replace.html)
ronniebaldino 04-26-2004 08:07 PM
I have decided that I am going to take care of my neglected chain tensioner 162000km.
What I want to know are two things:
Should I change the white PADS or the whole thing?
Should I replace the chain or is that not a big deal?
AFJuvat 04-26-2004 09:00 PM
Ahh like any good question the answer is: "it depends"
the tensioner itself should be eplaced every 90K miles or so. it is a hydraulic\mechanical part and will fail eventually. If you have records of a recent tensioner change, then just change the feet. Otherwise, change the tensioner.
Chain - don't really have to as long as it isn't damaged to stretched too much. If it makes you feel better, change it.
Check the sprockets on the camshafts for damage\cracking
AFJuvat
gtroth 04-27-2004 04:38 PM
I decided to change the whole assembly because I couldn't find the bottom pad (I don't think it is available). It doesn't wear nearly as much as the top pad, but it will still get brittle with time. I found out when I got in there that my tensioner was not quite right anyway - I could not compress it for removal.
The question these days seems to be whether or not to replace the J-tube. I didn't (it's ~$100, believe it or not). Mine looked looked shiny and new, but who knows. Better off changing it I guess.
