cv axle quest.
what is the easiest way to figure out which on of my cv's is going out? under any type of acceleration i can hear a small metallic noise and the faster the acceleration the faster the noise is. i can't tell which side it is coming from from inside the car when it is in motion. any suggestions?
85.5 944n/a 77 924 SOLD 2004 Dodge SRT-4 |
I get a couple of friends really soused and have them lean out of the back with the hatch open while I make hard power turns in a parking lot.
Hugh - So Cal 83 944 Driver Person NOT a 'real' Porsche -- Its Better!!!! When was the last time you changed your timing and balance belts and/or cam chain and tensioner? New Users please add your car's year and model to your signature line! Never break more than you fix! |
If you think its the CV's then take them off and repack them. Its a messy job but not that difficult. Be carefull not to trash the 12 point bolts that hold the CV's on. Once you clean them you will be able to see wich one is bad.
Roger Hall 81 924 N/A Some people are like Slinkies. Not really good for anything, but you still can't help but smile when you see one tumble down the stairs. |
Mein Gott!
Are they the original CVs? If so, a general rule of thumb is the driver's side is usually the first one to wear, as its close to the exhaust that dries it out faster.
Johnny 1987 944S 1984 944 (R.I.P.) 1972 Triumph TR6 - 100% trouble free between breakdowns 2003 BMW 325xi |
