fast924S's Avatar
Send a message via AIM to fast924S
Performance suspension and wheels Questions
1. Well I have decided that I will be selling my 17/7.5 inch rims because they dont fit. Im looking to buy a new set of some really sweet wheels THAT WILL FIT on a 87 924S, DOes anyone know where to look for a good quality, maybe lighter wheel??
2. I am also looking to do some suspension mods. I just installed a rear sway bar and Im looking to do some more suspension upgrades. Im very affraid to touch the rear torsion bars. How hard is it to install stiffer torsion bars?
3. What is a good suspension upgrade, I want to Do everything, Shocks, springs, torsion bars, sway bars. Im looking for something that is streetable, I dont mind if I can "FEEL" the road. It also needs to be good for MILD autoX and LIGHT-MILD track. SO what would be a good suspension Package for this type of use?????
Thanx alot guys
1986 951, Stock for now.
]87 924S Gaurds red- SOLD after 11 years of ownership
Old 02-17-2004, 04:35 PM
fast924S's Avatar
NO ONE WANTS TO HELP ME??
Old 02-17-2004, 09:00 PM
Certified Rennwerker
924Sman's Avatar
Send a message via MSN to 924Sman
Read my SIG.
T bars....Time consuming, you will need scales to balance- labor intensive job!
Not going to be in racing or AutoX, street use only......save the money and drive it stock.
Wheels are your call....not much to pick from for the 924S. 16" max by 8" width max. Try some BBS's or Fuchs go to wheelenhancement.com you will see what is available for you there for replacement Porsche wheels and aftermarket sets. Sman
PCA " I've been everywhere, done everything......just can't remember any of it!"
Old 02-18-2004, 01:50 AM
924Sman's Avatar
By the way how do you come up with 10:1 CR on a 87 924S?
There is no stock 10:1 CR you have 9.7:1
FYI.....944 CR pistons are 84-87 Eng Model-44.01/3/5/06...10.6:1
84-85 EM 44.02/4/7/08.......9.7:1
88 EM 44.09/10.......10.2:1
86-87 EM 44.07/08..........9.7:1 ***** your motor!
89 EM 44.11/12..........10.9:1
Sman
Old 02-18-2004, 02:02 AM
justin's Avatar
Fast924s, what are the offsets on the rims? Will they fit an 83 944,properly? How much for them?
Texas hosts the 928 Owner’s Club OCIC in 2009
www.928ocicdfw09.com
1980 928 5 speed and a few mods..........
928 OC member
PCA member
Old 02-18-2004, 09:30 AM
924Sman's Avatar
52.3mm on the 87
23mm on the 83.... yes but spacers are needed to fit.
These are Boxster wheels so the O/S is whatever the Boxster uses.
Yes a 17"X 7.5" will fit with the correct O/S or spacers when applicable. Sman
Old 02-18-2004, 09:46 AM
fast924S's Avatar
10.1 is from shaving the head down, Maybe its not exactly 10.1 but its close, I will do compression ratio test when I got it running agian. I would like to sell the 4 rims and tires for 1500 OBO, they are 17/7.5 turbo twist rims I will have pics soon
Old 02-18-2004, 09:08 PM
Send a message via AIM to TheCooler
I wouldnt bother with the torsion bars unless you wanna get really dirty. I would say with the money you get for the twists buy some fuchs and refinish them then get konis with coil overs all around. The car you got from me had rear koni adjustable ride heights on them ...I dont know how many miles were on them but they didnt seem too loose.
On another note....Theres a kid at our school who has another 944 and he cant pass emissions because he has a straight pipe ...Hes willing to buy my old exhaust off you for 100 I think ...but he wants to check it out first. His name is Ian ...ill get his # if your interested.
-2002.5 GTI VR6 24V 6SPD
-Kalahari Beige 89 Porsche 944S2
-87 VW GTI 1.8 16v
-2007 Ford PIMP(free)star ...company car....
-1999.5 Jetta VR6
Old 02-18-2004, 10:42 PM
fast924S's Avatar
sure give him my number and tell hime to call me. How many peopl do you know that a running 9 series cars in Guilford???
Old 02-19-2004, 02:08 PM
nah he lives in milford...he goes to our college. Ill give him your number next time I see him in class. Theres this other older lady at our school that had a red 85/2. Its in pretty decent shape too.
-87 VW GTI 1.8 16v
-1999.5 Jetta VR6
Old 02-20-2004, 05:42 AM
hi
i just bought a 89 porsche 944 n/a and i am looking to make some upgrades. After racing it a bit ive decided to do something about the suspension but im not sure where to get parts for it or what parts to get. There seem to be almost no parts for a 89 944 n/a for some reason all the parts are for older models or turbos. If anyone knows of a coilover kit or any other suspension upgrade for my car please post it. Thank you.
Old 04-25-2004, 07:54 PM
Get the M030 spec front ride-height adjustable Konis, then a proper auto-x alignment (lower a bit in the front and rear, -rear should lower a bit w/out re-indexing t-bars). Those will give you a very firm ride and eliminate a lot of your body roll. IIRC you have 23.5mm torsion bars, which should be adequate, the M030 spec 25.5s would be a nice upgrade, but the car shouldn't be imbalanced w/ stock rears. & Installing new T-bars is a pretty big pain. But do add the yellow koni shocks for the rear. Both the fronts and rears should be readily available used, you'll have to find out if the 951S spec fronts will fit, as those are quite available. IMO, M030 spec is just right for street, auto-x and light track/DE.
Old 04-26-2004, 11:03 AM
If you want streetable, but better handling you do the basic modifications I did:
26.8mm Front bar, Bilstein Gas Shocks
19mm Rear bar, Bilstein Gas Shocks
205/55-16 Front on 6x16
225/50-16 Front on 7x16 (I've running 6x16 to stay stock legal)
Lower the back rear to level the car
I'll find the car takes on a whole new feel with these minor changes.
Old 04-27-2004, 08:52 AM
Re: Performance suspension and wheels Questions
For the 924S, the 7 inch Design 90 wheels all corners is the way to go. The guys that I know are using the 7 inch D90s for the track events with great success. These wheels are light and because they are not as popular you can get great deals on them.
Mark
'86 944NA
Old 05-01-2004, 08:35 PM
I left the stock front bar and just replaced the 14mm rear bar with the 18mm rear bar. Cheap way to go and works great for the street and track.
I must try leveling, I've heard good things about doing that.
Mark
'86 944NA
Old 05-01-2004, 08:45 PM
fast924S's Avatar
What do the D90 wheels look like??? any web sites??
Old 05-01-2004, 09:41 PM
will944's Avatar
Send a message via AIM to will944
Like this
10 E92 M3
13 Jeep GC Limited
98 Jeep Cherokee
87 951
C3 Stingray
Old 05-02-2004, 12:41 AM
