out driving my 1985 (early half) yesterday
and noticed whenever i pressed the gas pedal that there was a LOUD clicking sound coming from the rear passenger side of the car. sound not present at idle or when in gear with clutch depressed reving motor any ideas on what this could be? |
CV Joints is my guess. Do a search and you'll find a sheet load of info on them.
83 944na - Gone but not forgotten. |
I will do that thanks!
if there is any thing else you may recommend I AM ALL EARS!!! |
Sounds like CV joints to me, that is what mine did and sounded like when one was starting to go out.
'83 arctic silver 944 n/a Power steering? who needs it! |
so i cannot tighten any bolts???
i just have to replace is this correct? |
Try tightening the bolts first, they could be loose. If not, sounds like it's time to replace them or rebuild/repack the joints.
'83 arctic silver 944 n/a Power steering? who needs it! Last edited by pearldrum; 05-25-2004 at 08:20 PM.. |
WONDERFUL!!!
thanks for the help. . . looks like i have a FUN weekend ahead YIPPIE!!! |
It's not that bad of a job, let us know if you run into something.
Ahmet
Cheers! |
