Don 944 LA's Avatar
Re-locating vents on early 944 ???
On the early 944 there are 2 air vents just above the center console.
Has anyone ever relocated them ???
I eventually want to install a " Shuttle " type PC. One in particular has a front panel that the radio and CD player will work even when the computer is turned off.
It has a nice wood look front. The board will take a P4 2ghz type processor and has an AGP and extra PCI. So I could put an All In Wonder Radeon graphics card for TV and games etc...
Hooked up to a flat panel touchscreen and also using the ATI remote that comes with the video card, would be a kicka$$ system in the P-Car
Anyway, do ya think that it can be done ???
944 85.0 Kalahari Beige -- Dead/Gone/NotForgotten (Ran Like a Raped Banshee) 944 85.5 Guards Red
Current Stable 944 83 Kalahari Beige manual rack, short 5th gear951 86 Guards Red, pristine TurboYou must not anger the Porsche Gods - you MUST leave one small item unrepaired, lest the Stuttgartians smite thine car with bad Ju-Ju-AF Juvat
Old 05-11-2004, 03:27 PM
Don 944 LA's Avatar
Heres the case I want to put in the dash
Click here for the specs
I was mistaken on some of the specs
Old 05-11-2004, 03:33 PM
SoCal Driver's Avatar
Of course this is in the future after you have your car running correctly?
As to the vents; pop off the center speaker grill and take a look. Think the air box will get in your way.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 05-11-2004, 03:36 PM
Burn the fire.
Brando's Avatar
The vents can be re-routed just by re-directing the hoses that connect to the front. Those you can bend around whichever way you want. As for fitting that PC in there, you know it's an awesome idea... just make sure you stock up on hand-saw blades.
[x] Working | [_] Broken: 2017 Victory Octane
[x] Working | [_] Broken: 2005 Ram 1500 SLT w/5.7L Hemi
"Drive it like you stole it."
Old 05-11-2004, 06:17 PM
