Has anyone ever put a turbo head on a N/A
Has anyone ever installed a 951 head on a N/A engine. If so what results did you get. Is it possible to do????
86 944 daughters
88 944 step-sons
07 Ranger 4x4
I have tons of spare parts, let me know what you need.
Old 05-12-2004, 08:19 PM
Man is always trying to exchange heads, usually on his favorite girlfriends. In either case, car or girls, it's a better fantasy than reality...
AJF
1998 Glacier White Boxster
1971 Fiat 124 Spyder
1999 Mercury Mountaineer
Old 05-13-2004, 05:00 AM
fast924S's Avatar
Send a message via AIM to fast924S
Do I search, I think some one has asked this before, From what I remember I dont think there is any good benifit from it, The air flow is all wrong.
1986 951, Stock for now.
]87 924S Gaurds red- SOLD after 11 years of ownership
Old 05-13-2004, 03:43 PM
MrPants's Avatar
Yea, you will decrease comp. ratio if you put on a head from a turbo. Also, i dont think it bolts up to an N/A manifold and so on.
As usual it is not financially feasable, unless you have a donor head, and even then doesnt make much sense
84 944 Non Alcoholic
Old 05-13-2004, 07:39 PM
ae1969's Avatar
Send a message via ICQ to ae1969
Actually a turbo head bolts right in...........
I wouldnt consider it a performance mod unless you are planning on adding a little forced induction.
Sodium filled valves, ceramic coated exhaust ports, stronger springs etc.....
You are better of taking an NA head and beefing it up if you are planning on making that NA rev a little higher....
Alex - PCA Polar Region - Boxster Muncher
86' 944 Turbo - Megasquirt - 326 rwhp/340lbft @ 18 psi SOLD
www.edmontonhomelife.com
www.edmontonrealestate.ws
Old 05-13-2004, 07:56 PM
scheistermeiste's Avatar
Send a message via AIM to scheistermeiste Send a message via Yahoo to scheistermeiste
at least you didnt ask how to put a turbo on your N/A! :-D
Special Edition 924S 1988 <- SOLD!
Asking if you should replace that timing belt is like asking if you should re-use a condom that may have in hole in it with a hooker.
Old 05-13-2004, 09:05 PM
Burn the fire.
Brando's Avatar
how do i...
[x] Working | [_] Broken: 2017 Victory Octane
[x] Working | [_] Broken: 2005 Ram 1500 SLT w/5.7L Hemi
"Drive it like you stole it."
Old 05-13-2004, 11:12 PM
1.2gees's Avatar
Send a message via AIM to 1.2gees
Yeah should drop right in, and get you no extra power...
Ahmet
Cheers!
Old 05-13-2004, 11:20 PM
fast924S's Avatar
I wonder if it will move the power curve around???
Old 05-14-2004, 03:19 AM
1.2gees's Avatar
Ports/valves should not be significantly different in size or shape. I do not THINK that the combustion chamber shape is any different in the head either. Therefore I would think not.
Also, the double valve springs MAY be a little stiffer, which would require more power for the valvetrain to be driven.
Ahmet
Cheers!
Old 05-14-2004, 06:13 AM
URIN 2ND's Avatar
So it seems the head itself is no different.
How about the camshaft?
Sean
'88 Porsche 944
'95 Volvo 940T
Seal Beach, CA, USA
Old 05-14-2004, 09:00 AM
I don't think the camshaft is different. In the shop manuals it shows the degress of timing to be the same on the opening and closing of the valves. I thought that a 951 head would have a better flow rate. That was the reason we were thinking of putting on the engine. The motor that we are thinking of putting it on is a true euro with 10.5 compression and slightly shaved head. We would also be using the 951 intake if we had to.
86 944 daughters
88 944 step-sons
07 Ranger 4x4
Old 05-14-2004, 12:40 PM
fast924S's Avatar
never hurts to try it out, You might need a adjustable cam gear to make up for the timming lost when the head was shaved
Old 05-14-2004, 01:49 PM
I have all of the parts, left over from parting out a 951, just don't know if it will make much difference. The car up to 143 at Rennsport in Daytona (not me driving!!!!). We are trying to figure some way to get more into the motor.
86 944 daughters
88 944 step-sons
07 Ranger 4x4
Old 05-14-2004, 01:55 PM
fast924S's Avatar
Raise the comp, Change the cam, Port and Polish, Hone the intake manifold out, Lighten the lower rotating assembley and balance, Light weight flywheel, Bigger throttle body, MAF kit. That should get you started to somthing nice.
Old 05-14-2004, 02:26 PM
How much did the Jacobs ingition help your car. As far as compression, like I said before, this is a true euro motor with the higher compresssion already and a shaved head. I don't think we can bump the compression anymore. Already have a burch header and with the pipe. Running a cherry bomb for a muffler. The car is run in SCCA and some PCA events. Can't do some of the mods that you suggested.
86 944 daughters
88 944 step-sons
07 Ranger 4x4
Old 05-14-2004, 03:27 PM
1.2gees's Avatar
The head IS different, though I don't know just how different it is. Cam is the same as some NAs (and very little different than others).
PS: Jacobs ignition helped with throttle response on my NA, but didn't really feel like it made more power.
Ahmet
Cheers!
Old 05-14-2004, 10:39 PM
fast924S's Avatar
I agree with 1.2gees, The jacobs ignition help with throttle response. what mods can you do???
Old 05-15-2004, 02:08 PM
