-   -   Replace short block? (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/163216-replace-short-block.html)
Stanton Horne 05-16-2004 06:16 AM
Can I replace my non-turbo 86 block with a 86 turbo block and use my everything else? I have a knock and metal filings around 2 of my camshaft lobes. My son said he was only driving at 72 mph.
SoCal Driver 05-16-2004 10:13 AM
No. Turbo short block has dished pistons to lower the compression ratio. The N/A doesn't. Also a slight difference in the casting where the head bolts up.
Think there is a special head gasket that will let a turbo engine use an N/A head but since you don't have the rest of the turbo system you would be getting less than 90 HP out of the combination.
Maybe just the thing for an aggressive son!
If you have problems with the cam then you need to check that the cam gear didn't come loose. There is a 12 point socket head under the dist rotor. A loose cam gear will also cause a knocking sound and the loss of the timing belt due to tracking problems.
ae1969 05-16-2004 06:48 PM
SOcal is right you cant use the complete short block because of the compression ratio that is determined by the dished pistons.
Now what is interesting is you could swap your NA pistons and rods and put them into the Turbo block (cranks are the same). You will notice that the turbo cylinders are thicker as well.
Everything will bolt straight up for that year.
I have seen turbo pistons rods go into NA block and vice versa. No issues either way.......well there are some but none for what you are comtemplating.
And if you play your cards right you can sell those turbo pistons and rods and make some of your money back. :)
SoCal Driver 05-16-2004 09:20 PM
Just a side note on rods; the rods in the 83's are forged just like the turbos.
evox15 05-26-2004 01:37 PM
I'm kind of looking into this, I actually want to have the lower compression. Barring the compression difference, will the N/A head and all other N/A accesories bolt on the the Turbo block? So Cal said something about casting differences, is this true?
Stanton Horne 05-26-2004 02:06 PM
I don't know yet, and this compression thing has me interested - especially since I have read that the 924S engine has more compression but less horsepower at 5500 rpms - so I may end up with a 924S engine in my 1986 944.
SoCal Driver 05-26-2004 02:15 PM
Why do you want the lower compression?
Also I've heard of the NA head being used on the turbo but with a "special" gasket. Reason was to get a larger exhaust valve and exhaust port with out the ceramic lining. Used for racing.
Stan, Stick the 924S engine into the 86 using the 86's fuel rail and lines.
