fuel rail is loose but wont come off!
Hey guys as you know I am resealing my injectors but after removing all 4 bolts, wiring, fuel hoses, etc. My fuel rail wiggles but wont come off! I cant see any other connected points! I dont want to break anything so I opted to ask you guys first!
Thanks, (waiting)
Old 02-02-2003, 11:25 AM
Scott R's Avatar
Did you remove the metal clips on each injector?
If you did then you may need to apply some upward prying force to get the rail to pop off the injectors.
2021 Model Y
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 02-02-2003, 11:54 AM
I just pulled mine outa the ports with the clips on. you have to install them with the clips on to get the right depth so it seams natural to leave the clips on while removing... try twisting the injectors in their holes. one of my injectors had no clip and it stayed in the port
"porsche it's an institution"
Old 02-02-2003, 02:36 PM
Scott R's Avatar
With the clips on you can damage the injector. If the force is too much then the clip will release and damage the plastic seat.
Ask me how I know this..... Also you can re-install without the clips, no problem. The clip should go on the upper of the two notches on the injector.
2021 Model Y
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 02-02-2003, 04:08 PM
Thanks guys I got the rail off and injectors cleaned up...waiting on the fuel dampener to see if that is the culprit of all the BS!
Thanks a lot
86 951 Zermatt/Burgundy
"Its what we do with the time that is given to us that counts, so drive a Porsche"
2001 996 twin turbo Black/Red
1986 951 Zermatt/Burgundy
Old 02-02-2003, 10:55 PM
Thanks for the tip to protect the injectors scott.
Old 05-17-2004, 07:49 AM
SoCal Driver's Avatar
Take a two piece length of fuel hose that will fit snugly over the output end of the injector without the plastic hat. Fill this with solvent (enamel paint thinner will work or charcoal starter fluid) and blow air back through the injector. This will blow out most of the crud caught up in the filter screen on inlet side of the injector.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 05-17-2004, 11:59 AM
