Wardog's Avatar
924 parts into 944.....help!
I need to know which part from a 1985 924 from this list cannot be use on a 1986 944 NA
- rear wheel bearings
- emergency brakes parts (complete rebuild kit)
- axles.......cv joints.....everything related to this
- front windshield
- front lights lifter engine
- rear hatch....
thatŽs about all
any help or tip is usefull
thanks
Step on it!!!!
Old 05-17-2004, 08:42 PM
ae1969's Avatar
Send a message via ICQ to ae1969
85' ? 924
How about some pics of your progress....
WIth the PORSUPRA or SUPRASCHE
Alex - PCA Polar Region - Boxster Muncher
86' 944 Turbo - Megasquirt - 326 rwhp/340lbft @ 18 psi SOLD
www.edmontonhomelife.com
www.edmontonrealestate.ws
Old 05-17-2004, 09:18 PM
Used & Abused
Originally posted by ae1969
85' ? 924
Yes, Porsche still produced the 924 2.0 for ROW till 85
Yeah, you never did post pictures though you promised at least 6 times to do so. Let's see em!!
83 - 944, daily driver
62 - VW Karmann Ghia, never moving restoration
"Oh Bother," said Pooh, as he chambered another round.
Old 05-17-2004, 09:37 PM
SoCal Driver's Avatar
I think you can use everything listed. Something concerns me on the CV joints. Maybe that the later CV joints were just a bit stronger. But if they fit the axle and the recivers on the trans and stub axles I guess they will work.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 05-17-2004, 10:33 PM
Burn the fire.
Brando's Avatar
I'd put my money on transferring the 944 parts to the 924 though...
[x] Working | [_] Broken: 2017 Victory Octane
[x] Working | [_] Broken: 2005 Ram 1500 SLT w/5.7L Hemi
"Drive it like you stole it."
Old 05-17-2004, 11:19 PM
Rear wheel bearings can't be used as 924 uses steel trailing arms and 86 944 uses alu arm. Windshield is different. CV joints can be used.
Axles not sure about, but will check the part numbers.
From November 2012; Precision Porsche Specialist
Sussex UK, +44 (0)1825-721-205
2001-2012 Gerber Motorsport Inc. 206-352-6911
07.15.06 1996 Ducati 900SP. Suprisingly enough, it's red
08.16.09 1999 Kawasaki ZRX1100. Green.
Old 05-18-2004, 07:00 AM
Yeap. Did say 86 didn't he. Not the rear bearings for sure.
The axles are also a different length.
Good to know about using the CVs.
Old 05-18-2004, 09:44 AM
Wardog's Avatar
sorry.....I havent been able to post the car progress images cause I lost the cable......news.......engine mounts fits almost perfect.....brake booster is on the intake way so It has to be removed and placed somewhere else.....the supra radiator is too big, so weŽll be using the 944 radiator with both fans working all the time......if this doesnt work, weŽll use the subaru legacy radiator and fans.........used the supra pressure plate and 944 disc......oil pan hits the arm so it has to be cut a litle....ŽweŽll use the nissan 180sx turbo fuel pump for now, until the supra fuel pump arrives.........soon IŽll pot pics.....sorry.........
Step on it!!!!
Old 05-18-2004, 01:08 PM
Chris_924s's Avatar
924 was mfg up until 85, brought back in 86 as the 924S. late 924 and the early 924S never made it into the states.
TENSION YOUR SOCKS!
88 924S Guards/ Black ~ 10 years as a Daily Driver and STILL SMILING!
87 NA Diamond Blue Metallic ~ Gone
Old 05-19-2004, 06:08 PM
