A/C Conversion
I'm converting my 85/1 to R-134 and Im having a real space problem w/ the suction valve fitting on the compresser - wants to use the same volune already occupied by the alternator/bracket. Anybody got a part #/source for a really short 90 suction valve or did you just use a shorter drive belt so the compressor hangs down further?
Shorter belt for the early cars with the low side on the compressor, here you go. Works for me. It's one inch shorter than the original.
http://www.napaonline.com/cgi-bin/n...mp;prmenbr=5806 Original belt. http://www.napaonline.com/cgi-bin/n...mp;prmenbr=5806 SmileWavy |
Thank you very much. I can't get the links to work but if NAPA has um, I'll find um.
oops, sorry. New belt: http://www.napaonline.com/cgi-bin/ncommerce3/ExecMacro/NAPAonline/search_results_product_detail.d2w/report?prrfnbr=15539275&prmenbr=5806
Original belt: http://www.napaonline.com/cgi-bin/ncommerce3/ExecMacro/NAPAonline/search_results_product_detail.d2w/report?prrfnbr=15539279&prmenbr=5806 Just for resource purposes, not sure if pelican has them or not. |
Thanks a million. I don't see the shorter one on Pelican
| All times are GMT -8. The time now is 04:09 AM. |
