1989 944 Balance shaft belt replacement
How do you replace the balance shaft belt on a 1989 944 that has the self tensioner? Thanks
Old 05-17-2004, 02:16 PM
SoCal Driver's Avatar
The balance shaft belt does not use the tensioner. The timing belt does.
Should replace both at the same time.
Did the balance belt break?
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 05-17-2004, 03:15 PM
The balance shaft belt broke. It looks like it was in decent condition and the timing belt looks fine but I probably should replace them both. I do wonder why the one belt broke.
I have plenty of time to do the work.
Thanks for the expertise or experience... or both
John
Old 05-17-2004, 06:05 PM
Do both. Always do both. The tension on the timing belt is more critical than the balance belt tension. However the balance belt can be a bit loose compared to the timing belt.
The tension pulleys should be replaced at the slightest indication of drying out and/or getting loose. The smooth rollers are there to kept the belt from slapping around. These should be replace if they are loose.
Also check out Danno's Racer-X's site: http://members.rennlist.com/951_racerx/
Old 05-17-2004, 10:44 PM
1989 944 timing belt replacement
Do you have instructions for replacing the timing belt and balance belt for a 1989 944 that has the self tensioner?
Thanks,
John
Old 05-21-2004, 01:24 PM
Feelin' Solexy
Tishabet's Avatar
John,
check out the info on clarks-garage.com
I used his garage "how to" section to change the belts on my 89 with no problem.
Grant
In the stable: 1938 Buick Special model 41, 1963 Solex 2200, 1973 Vespa Primavera 125, 1974 Vespa Rally 200, 1986 VW Vanagon Syncro Westfalia, 1989 VW Doka Tristar, 1995 Toyota Land Cruiser, 2011 Pursuit 315 OS, 2022 Tesla Y
Gone but not forgotten: 1973 VW Beetle, 1989 Porsche 944, 2008 R56 Mini Cooper S
Old 05-21-2004, 02:17 PM
