-   -   A 'Where can i get' and my 924 update (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/164100-where-can-i-get-my-924-update.html)
Brando 05-21-2004 11:21 AM
This Tach?
http://forums.pelicanparts.com/uploa...1085163652.jpg
What be the part number for it? Maybe my mechanic can get ahold of it. Oh yeah, i also suggest re-locating your tach to the middle gauge spot :) Mine will be there shortly after i re-wire some things.
Also, yesterday i drove the 924 over to my mechanic, who did a bit of tuning up (adjusted timing and idle throttle adjustments). Sounds a bit better. Also commended me on a job well done! :D Unfortunately, i replaced my turn-signal fuse and after starting the car smelt wires burning, and saw some smoke. Popped that right out. Looks like i'll be installing a cab harness this weekend. I'm soooooooo looking forward to that. :rolleyes:
Don 944 LA 05-21-2004 11:32 AM
As far as moving the tach placement to the middle position:
Think of this... are you a " 10 & 2 o'clock driver ". If you are then that may be usefull.
If you are a one hander ( Like me ), the tach is in a good visable spot. The upside down tach really is usefull.
I don't have a working speedometer, so I never even look there.
I have the GPS off to the right side to show my speed etc...
( You have seen it )
Just my $.02
Don
