Porsche Crest Water Pump Replacement
Hi,
I am going to replace the water pump on my early 1985 porsche 944 and heard that this job is quite an ordeal. I was wondering if anyone had any suggestions and if anyone knows where I can get the tool to get the camshaft and balance belts tool that the Haynes manual says only mechanics can get. Thanks.
Old 05-23-2004, 05:02 PM
SoCal Driver's Avatar
Aftermarket. Krikit (sp). About $10
Also check out www.clarks-garage.com for more info.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 05-23-2004, 05:09 PM
If your 944 is like a 951 (and I think it is), you are going to have to lock the crank shaft at the starter housing in order to remove the crank pulley. Crank pulley has to come off to get rear dust cover of timing belt housing out. Water pump is behind that.
Oh, oh, SoCal, you are starting something with Krikit comment. Actually, I've used one for 7 years now. Works just fine.
Lawrence
1986 951
2002 SLK32 AMG
1987 328GTS
2011 528i
Old 05-24-2004, 04:03 AM
Starting something? Not with the Krikit. One of these days I have to get one to check my custom tensioning.
Old 05-24-2004, 07:15 AM
TSNAPCRACKLEPOP's Avatar
well, if you are going to do the pump, then you are the mechanic, so you can find the tool, or borrow one from a mechanic friend. where are you located??? upgrading to the autotensioners??
chance favors the prepared mind
1987 944 n/a 5spd. who remembers dial phones?.
'STOP FIXING THINGS ONE STEP BEFORE YOU BREAK SOMETHING ELSE"
Old 05-24-2004, 09:18 AM
Just thinking out loud
mattdavis11's Avatar
TSNAPCRACKLEPOP, twist method.
91 FJ80
84 Ram Charger (now gone)
Old 05-24-2004, 09:29 AM
yes, twist, ....and shout!
Old 05-24-2004, 09:52 AM
I some how don't think socal is worried about his method, nor should any other who does the same. The auto tensioner gives you a peace of mind? I call bs on that, they fail too.
91 FJ80
Old 05-24-2004, 10:10 AM
hey, replace all your oil seals for peace of mind. i put a timing belt on a car once and didn't replace the oil seals, then they leaked. what an annoying job to do twice. good luck
Parting out an 83 with black interior and two red racing seats
Old 05-24-2004, 09:46 PM
