Just thinking out loud
New bushings, question
I finally finshed up the front end, and wow what a difference! I went with factory rubber, except for the caster bushings (weltmeister reds). Now the car creeks under braking. I'm guessing that those need to set, but not sure. Has anyone else experienced the same? It has not been to the alignment shop yet. Thanks
83 944 91 FJ80 84 Ram Charger (now gone) |
Give then a few weeks to set in.
Hugh - So Cal 83 944 Driver Person NOT a 'real' Porsche -- Its Better!!!! When was the last time you changed your timing and balance belts and/or cam chain and tensioner? New Users please add your car's year and model to your signature line! Never break more than you fix! |
Thank you sir! Now I can sleep well tonight. That was a fun project, and I am amazed in the difference. Thanks for all the help folks.
