Unhappy Still runs rough
Wife just got home from school again and p car was running rough. She said it ran fine going to work express way 20 miles at 80MPH. She made it almost all the way home before it acted up. It was missing only a little when i accelerated the trottle but it still missed. it ran twice as rough at an idle. It acts like a bad fuel filter or fuel pump but it only does this after the car has been driven 50 or so miles. I smell no gas and see no leaks on the engine. I'm planning on replaciong the fuel pump, replacing my already new fuel filter and also dropping my ( Ithink i have a overflow leak on top somewhere) Gas tank and flushing it out.
ALLONS
2002 Boxster
Old 05-26-2004, 07:16 PM
SoCal Driver's Avatar
Clogged injector(s). Unplug one at a time and see which is not working. Yes you have to plug it back in before you go to the next one.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 05-26-2004, 07:32 PM
THanks SoCal. I'll check out my injectors. Can they be cleaned or do I have to replace them? Do you happen to know Why does it do this only when it gets warmed up?
ALLONS
2002 Boxster
Old 05-26-2004, 08:15 PM
If you strike out with the injectors, try the reference sensor on the fly wheel. The injectors get some kind of signal from here.
I had the same problem for about 6 months before I gave up and took it in for diagnostics. Cost me $325 but she runs great now.
86 NA
Old 05-27-2004, 04:33 AM
Send a message via AIM to TheCooler
Have you checked the wires for arking or the cap and rotor for wear?
-2002.5 GTI VR6 24V 6SPD
-Kalahari Beige 89 Porsche 944S2
-87 VW GTI 1.8 16v
-2007 Ford PIMP(free)star ...company car....
-1999.5 Jetta VR6
Old 05-27-2004, 05:29 AM
As the responses pour in you will see that there are a lot of potential problem points to consider. This is a process of structred elimination. If you start throwing parts at it you may or may not hit the problem. A bit of testing goes a long way to keeping your pocket book from going flat.
Let me add another point; the fuel pressure regulator and dampener. These as well as the sensors are heat related.
Old 05-27-2004, 07:31 AM
Angry same
Okay I checked each injectorlike SoCAl suggested , all had the same 2.9 ohms. Ran engine and pulled one injector plug at a time and all checked out okay. ( pull onr and it ran badly) Took p car for drive and I cannot get it to run rough. My wife thinks it's a vapor locking problem as on the days it acted up it was in the mid to high 90's. I hate to admit it but she might be right. while I still don't think it is vapor locking per say , Because it's not chugging but rather just missing the heat does seem to be a factor. Could a fuel pump or dampner valve be breaking down under very hot conditions?
ALLONS
2002 Boxster
Old 05-29-2004, 11:27 AM
ae1969's Avatar
Send a message via ICQ to ae1969
Have you verified fuel pressure ?
Alex - PCA Polar Region - Boxster Muncher
86' 944 Turbo - Megasquirt - 326 rwhp/340lbft @ 18 psi SOLD
www.edmontonhomelife.com
www.edmontonrealestate.ws
Old 05-29-2004, 12:28 PM
