Don 944 LA's Avatar
Flopping around radiator ????
I just replaced my upper radiator hose ( my fault - Doh !!! )
and, I noticed that NOTHING was holding the radiator in except the hose pressing it towards the front of the car.
Is this normal ????
Don
Unfortunately, I don't have the space or ability to look closer at it. I can't do ANY work on a car in my apartments. I was lucky to squeak in the hose replacement.
944 85.0 Kalahari Beige -- Dead/Gone/NotForgotten (Ran Like a Raped Banshee) 944 85.5 Guards Red
Current Stable 944 83 Kalahari Beige manual rack, short 5th gear951 86 Guards Red, pristine TurboYou must not anger the Porsche Gods - you MUST leave one small item unrepaired, lest the Stuttgartians smite thine car with bad Ju-Ju-AF Juvat
Old 05-29-2004, 11:36 PM
Used & Abused
No.
I did a search cause I remember someone posting it before.
Radiator and Lower hose...
Hope it helps
83 - 944, daily driver
62 - VW Karmann Ghia, never moving restoration
"Oh Bother," said Pooh, as he chambered another round.
Old 05-30-2004, 03:00 AM
Had the same problem awhile back, radiator/fan assembly moved aft and the fan ate my radiator hose. There are two rubber radiator mounts that go in/on the bottom of the radiator. one was missing, the other one died of old age. They are relatively easy to replace and don't require disconnecting anything. You should be able to lift the radiator "up" and "aft" and replace/install the rubber mounts. You have to press them into the holes (you'll see). The only difficulty factor is the ground clearance. If you can raise the front end a little, you'll be good to go.
84 944 n/a, aka "The Pooch"
84 BMW 318I, 213,000 miles, donated to the needy.
65 Ford F100 Fleetside, My restoration project.
74 Toyota Landcruiser, loved it!
65 VW Westphalia camper, sold
57 VW Bug ragtop, sold (sigh)
64 Karmann Ghia, sold and sadly missed.
Old 05-30-2004, 04:02 AM
zehnd's Avatar
Another thread
83 944na - Gone but not forgotten.
Old 05-30-2004, 08:26 AM
Don 944 LA's Avatar
Originally posted by zehnd
Another thread
Oh yeah, I remember that thread now.
Thats exactly my problem.
I just have to get the missing pieces and go from there.
Thanks again all.
Don
Old 05-30-2004, 02:32 PM
are the 2 brackets that go on top that hold the 2 top rubber bumpers there. I think I have 2 more of those. I sold a set of them and 2 rubber bumpers and a extra fan to someone on here last week that had the same problem. You actually have 4 of the little rubber mounts, 2 on top and 2 on bottom. Like I said the 2 top ones are held in with the 2 small brackets.
86 944 daughters
88 944 step-sons
07 Ranger 4x4
I have tons of spare parts, let me know what you need.
Old 05-30-2004, 09:17 PM
Don 944 LA's Avatar
( going from memory )
I have # 4 ( 2places )
I DON'T have #2 (2pc ) and #3 (2pc)
So , I'll just order them and put them on the next time I am somewere that I can work on it.
Till then, I should be OK with just the hose holding everything in. Unless I pull a Dukes of Hazard ... Come on Flash !!! kew kew
Old 05-30-2004, 09:35 PM
