Porsche Afm On 86 944
I NEED TO FIND A PLACE TO HAVE MY AFM REBUILT IF POSSIBLE?DON'T WANT TO SPEND 500.00 ON A NEW ONE IF I DON'T HAVE TO.
Old 05-31-2004, 02:48 PM
check out repair guide http//frwilk.com great step by step with photos
AJF
1998 Glacier White Boxster
1971 Fiat 124 Spyder
1999 Mercury Mountaineer
Old 05-31-2004, 03:19 PM
SoCal Driver's Avatar
www.frwilk.com
Specifically : http://frwilk.com/944dme/afm.htm
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 05-31-2004, 09:56 PM
Then the question is how do you know your AFS (Porsche calls it an Air Flow Sensor) is bad?
Old 05-31-2004, 09:58 PM
Don 944 LA's Avatar
Cuz, it's got his Caps Lock on and he can't get it off.
There isn't a day that I don't tweak mine ( now that I'm smoggable), the concept is simple, there's nothing to break or wear out but the variable resistance swiper track, and thats easily correctable with FR Wilks procedure...
The places that sell Refurbished AFM / AFS are ones that (hopefully) put them on a bench and adjust the spring tension on the flapper because a previous owner messed with it and got it out of spec. I just paid $120 to get mine in spec, only to find out that the guy just set the idle mixture screw to spec.
944 85.0 Kalahari Beige -- Dead/Gone/NotForgotten (Ran Like a Raped Banshee) 944 85.5 Guards Red
Current Stable 944 83 Kalahari Beige manual rack, short 5th gear951 86 Guards Red, pristine TurboYou must not anger the Porsche Gods - you MUST leave one small item unrepaired, lest the Stuttgartians smite thine car with bad Ju-Ju-AF Juvat
Old 05-31-2004, 10:34 PM
Don 944 LA's Avatar
Originally posted by FR Wilk
You can tell an AFS is "going bad" when it starts to smell like week old fish, it will start talking with a gutter British accent, and it will start smoking cigarettes.
ROFLMAO
But at least it doesn't smell like a bucket of fish under the stage at a willie nelson concert ( National Lampoons class of 1984.. check it out.. good comedy )
Old 05-31-2004, 11:28 PM
That's why they guddle about with it!
Old 06-01-2004, 07:13 AM
THE CAR ACTED LIKE IT WAS OUT OF GAS AND WOULD NOT RUN.INSTALLED USED AFM OFF ANOTHER CAR AND IT RUNS FINE NOW.THE CAR WAS DUNKED IN A FLOODED STREET.I BOUGHT IT WITH A NON RUNNING MOTOR(2 BUSTED RODS AND A HOLE IN THE BLOCK)IT HAD BEEN SITTING FOR 8 MONTHS BEFORE I BOUGHT IT.UPON REMOVEING THE COVER ON THE AFM I FOUND A LARGE AMOUNT OF WATER AND CORROSION.
Old 06-01-2004, 09:03 PM
