stanman72's Avatar
85.5 944 Headlights
I need to replace the headlamp on my 944. is this as easy as turning a few screws on the headlamp frame?
85.5 Porsche 944 NA, 2.7 liter motor, Guards Red, 155k miles
Old 06-03-2004, 12:40 PM
andrewgoh's Avatar
Do you mean the headlamp lenses or the whole assembly?
The headlamp lenses can be removed by: (1) removing the plastic guard - a couple of screws if I recall correctly, and (2) removing the metal ring holding the lenses - 3 screws...note: check carefully...do confuse the alignment screws with the metal-ring mouting screws.
Old 06-04-2004, 01:51 AM
stanman72's Avatar
Thanks for the info!
Old 06-04-2004, 05:48 AM
SoCal Driver's Avatar
Damn. That's a nice rag.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 06-04-2004, 08:17 AM
andrewgoh's Avatar
Wifey has a thing against loose threads on bath towels...if she sees a thread unravel from the fabric...it gets decomissioned right away....any guess who becomes the lucky recipient?
I believe current count is 15+ bath towels in the garage. I really should install a bathtub for myself in the garage!
Old 06-04-2004, 09:33 AM
