Send a message via AIM to SlowToady
Cooling fan not turning on?
I don't think my cooling fans are turning on, because my car gets REALLY hot. In traffic the thermostat will go from about the 1/4 bar all the way up to the red. So far, I've always managed to get it shut off for a tick (or um, increase the air flowing over the engine..) before it gets into the red, but it was pretty close today and the other day. Today, when I was at the library I came out, started it up (I was gone for ~30 seconds) and it was just under the red after I backed out of the parking spot so I shut it down and popped the hood. I waited two minutes or so and started it back up, and the cooling fans didn't come up. The thermostat was still at 3/4. I managed to not hit many red lights so I kept it in the middle-ish on the way home, but I'm really getting worried.
How can I fix this? I tried looking at the diagram in the Haynes Manual, but electronics is all gibberish to me (especially since I can't plainly see the circuits). How would I test if the fans are even getting any power to them? Are they connected to a fuse? If so, what number? Then at least I could test the fuse.
Also, I was thinking about upgrading to a Turbo radiator, would this yield any benefit? I'd like to improve my cooling system a bit because unfortunatley, my area has gotten very built up and there is a lot of traffic--something my 944 really, really doesn't like.
Thanks a lot guys
I turn away with fear and horror from this lamentable sore of continuous functions without derivatives. --Charles Hermite
Fakelife.com Nothing to do with archery anymore. Porsche/BMW/Ferrari/Honda videos
Old 06-04-2004, 10:48 AM
SoCal Driver's Avatar
Don't think the turbo radiator fits.
Turn on the A/C and check if the fans come on. If not check the fuses. Seems that between the inexpensive temp switch in the radiator and the very expensive relay it's usually the relay that fails.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 06-04-2004, 11:22 AM
When I turn the A/C on, the fans come on. So does that mean it is the radiator temp switch?
Old 06-04-2004, 03:40 PM
I would think so. You can test it by unplugging it and putting a jumper wire on the plug. Turn on the key and the fans should come on.
86 944 daughters
88 944 step-sons
07 Ranger 4x4
I have tons of spare parts, let me know what you need.
Old 06-04-2004, 04:01 PM
He has the three pin temp switch -- later 944. Short out between the center pin and one of the outer pins. One side turns the fans on low the other on high.
Really a trick design on the later models. Two speed fans. Guess the engineers were trying to buffer the rapid heat rise inherent in the 944's.
Old 06-04-2004, 07:10 PM
