Eli K's Avatar
Red face Another horn question
Did a search but couldn't find anything related directly to what I am experiencing.
My '84 has an aftermarket MOMO steering wheel, with a disfunctional horn. After taking the wheel off I noticed that there was NO ground wire at all, not anywhere in sight. I rigged a wire and grounded it near the combo switch. The horn started working but would honk on it's own each time I turned.
Does anyone know exactly where the horn should be grounded?
Thanks in advance!
Old 06-04-2004, 06:57 PM
SoCal Driver's Avatar
"Sounds" like it needs a new wiper. The circular one that screws to the back of the steering wheel adaptor.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 06-04-2004, 07:02 PM
scheistermeiste's Avatar
Send a message via AIM to scheistermeiste Send a message via Yahoo to scheistermeiste
check your to see if your fuse for the cluster lights are blowing aswell. when i put mine oni had to grind down the piece that turns my blinkers off because everytime i turned the metal from the hub would short out in a thin piece of metal that brings power to the wipers...
Special Edition 924S 1988 <- SOLD!
Asking if you should replace that timing belt is like asking if you should re-use a condom that may have in hole in it with a hooker.
Old 06-04-2004, 09:16 PM
Eli K's Avatar
SoCal, I am confused...what wiper are you talking about?
Old 06-05-2004, 07:27 PM
