-   -   1 radiator fan out... (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/166372-1-radiator-fan-out.html)
brian carignan 06-05-2004 10:42 AM
Hey everyone, sorry if this had been covered recently, I scanned passed post quickly, anyway, I have a small(??) problem with my wiring to my fans. One will only work. Doesn't matter which fan, it's one of the connectors. I went into the parts shop an they said I'd have to order an entire wire harness from a factory dealer...or try to rige something up. How can I do that? I don't mind if the fans turn on when the car starts or could I get that one fan to kick on when the good wire connector fans starts. Any help is greatly appreciated. Thanks
brian
SoCal Driver 06-05-2004 10:49 AM
Did you check the fuses in the fuse box? One for each fan. Also the large silver relay at the back of the fuse box.
There are also two wire wound ceramic resistors behind the glove box. One for each fan.
In other words I don't think the harness is to blame -- yet.
Copyright 2018 Pelican Parts, LLC - Posts may be archived for display on the Pelican Parts Website
