1 radiator fan out...
Hey everyone, sorry if this had been covered recently, I scanned passed post quickly, anyway, I have a small(??) problem with my wiring to my fans. One will only work. Doesn't matter which fan, it's one of the connectors. I went into the parts shop an they said I'd have to order an entire wire harness from a factory dealer...or try to rige something up. How can I do that? I don't mind if the fans turn on when the car starts or could I get that one fan to kick on when the good wire connector fans starts. Any help is greatly appreciated. Thanks
brian
1985.5 944 60,000 miles (with new timinng belt)
Old 06-05-2004, 10:42 AM
SoCal Driver's Avatar
Did you check the fuses in the fuse box? One for each fan. Also the large silver relay at the back of the fuse box.
There are also two wire wound ceramic resistors behind the glove box. One for each fan.
In other words I don't think the harness is to blame -- yet.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 06-05-2004, 10:49 AM
