interor light, the clock an the cig. lite
I've got a few weird problem that I don't know where to begin. First off when I open my door that pleasent little beeping sound doesn't happen. My fasten seat belt light doesn't blink when I turn the engine over an my interior light no longer comes on. I have to leave the interior light switch on the most forward setting (towards the winshield) or the clock and cig lite outlet does not work. Where do I start, I did the 1st obvious, checked the fuses, everything seemed fine. suggestions anyone? thanks
brian
1985.5 944 60,000 miles (with new timinng belt)
Old 06-05-2004, 10:47 AM
Send a message via AIM to toolboy62 Send a message via Yahoo to toolboy62
they are all on the same fuse, I have issues with that ckt. on my car as well, I suspect it has to do with the aftermarket stereo but I have not pulled it yet to check it out. the fuse is blown right now but the clock "sometimes" works which says to me that something's backfeeding that ckt.
nate
1988 944... and a bunch of other cars
Old 06-05-2004, 02:32 PM
Send a message via Yahoo to Cebu
Check the circuit plunger in the door jam on the driver's side it may be stuck or the ground wire to the plunger may be broken. If the hot wire is broken the fuse will blow.
85.5 944na
Automatic
V-65 Magna
94 Impala SS
Old 06-05-2004, 03:23 PM
Don 944 LA's Avatar
as far as the interior light...
Check that it hasn't melted the plastic inside on the switch. I had to tweak mine so that it would work.
944 85.0 Kalahari Beige -- Dead/Gone/NotForgotten (Ran Like a Raped Banshee) 944 85.5 Guards Red
Current Stable 944 83 Kalahari Beige manual rack, short 5th gear951 86 Guards Red, pristine TurboYou must not anger the Porsche Gods - you MUST leave one small item unrepaired, lest the Stuttgartians smite thine car with bad Ju-Ju-AF Juvat
Old 06-05-2004, 05:27 PM
thanks guys, got pretty much everything going an my electrical problems are back down to a minimum. Thanks Don for you other advice yesterday too.
brian
Old 06-06-2004, 04:26 AM
