Exhaust manifold and turbo
Well, i'm in the final process of taking out my 951 engine. Pretty smooth overall... I was always a bit frightened about the nuts that hold the exhaust manifold to the head, yep, the rusty ones. Well, i just put on my 13mm socket and tried it, expecting to be all stuck and all they just came off. Should be a bit careful, i only took two off so far, but that took no effort at all. Can it be that my exhaust manifold has just been loose all those years??
Also: i've been trying to find out if the turbo is connected to the block in any way. It does seem it's somehow connected to the block, but i don't see a bolt or anything. It would be nice to be sure EVERYTHING is disconnected before i drop the engine out
Any tips on the above would, as always, be welcome
Old 06-05-2004, 05:48 PM
Man..just think..you could have been having boost creep all those years youve owned the car
Old 06-05-2004, 05:51 PM
Well, no kidding, it really seems as if the nuts are pretty loose. Haven't looked up the torque specs yet, but i can't find any traces of leaking gasses or anything... well, it'll be rebuild and resealed all round, so no big problem.
Old 06-05-2004, 05:54 PM
ae1969's Avatar
Send a message via ICQ to ae1969
Uhmmm the exhaust nuts are torqued to 20NM.... Normally people end up pulling the studs..... so consider yourself lucky.
You have 2 bolts holding the turbo........
Accesible from underneath. NOT FUN.
If you are dropping the engine leave the turbo on if you can.... otherwise remove the AC/Alternator and you should be able to see the 2 allen bolts. The turbo is held by the motor mount ...
Alex - PCA Polar Region - Boxster Muncher
86' 944 Turbo - Megasquirt - 326 rwhp/340lbft @ 18 psi SOLD
www.edmontonhomelife.com
www.edmontonrealestate.ws
Old 06-05-2004, 06:40 PM
Thanks ae, i'll look that up. I guess removing the exhaust allway around the enigne is better anyway. At least the cross pipe should be removed and i think that involves disconnecting it at the turbo. And while the engine is still in the car i think i'll pop off the exhaust manifold as well, as it goes pretty smooth.
Old 06-06-2004, 02:21 AM
