bearone2's Avatar
Talking antenna replacement
i've got the powered setup but don't need it to work up and down.
the telescoping part broke off leaving the threaded/hex head screwed in on the fender, with a two inch stub going down in the hollow shaft.
are the antennas advertised at pelican, the hex nut/threaded part with the telescoping antenna what you get when you replace the mast or is it something else altogether.
87 951, K27/6, Almond Beige, 17" Turbotwist
87 944S, alpine white, 5sp died a violent death
84 944, silver/brown, auto, gone but not forgotten
"may the force be with you"
Old 06-05-2004, 08:43 PM
SoCal Driver's Avatar
Stock electric antenna has a replaceable mast. You get the mast with a long nylon tail hanging out of it and instructions on changing it.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 06-05-2004, 09:42 PM
I don't mean to hijack this thread but also have a quick ? I purchased my car and the PO had the stereo disconnected. When I put the new one in I noticed the radio ant wire was cut, then I started looking for the antenna, no antenna or better yet I don't have any holes where one would go. So my rammbling question is this...where is the ant on a 1985.5 na 944? I have no holes in me fenders, could be some aftermarket but if it was they did a great cover up. Got a pic od your ant anyone? thanks in advance.
brian
b
1985.5 944 60,000 miles (with new timinng belt)
Old 06-06-2004, 04:37 AM
Maybe integrated in the windscreen? My '88 951 has it, don't know about the older models. It's a very basic system, near the ecu there is a connector from the window that is amplified to the radio.
Old 06-06-2004, 04:44 AM
Thin gold wire around the windshield. The connection is on the passenger side behind the battery. There is an amplifier behind the golve box. The antenna wire should have the coax as well as a second small wire to power the amp.
Old 06-06-2004, 09:31 AM
Back to the early electric antenna; Yours may just need the stock mast replaced. Depends on IF you can get the old mast out including the nylon tail.
Old 06-06-2004, 10:21 AM
okay, thought something like that might be it too, hmmm, thin gold line around the winshield, well, I'm in a lil trouble, this is definatly not the factory windshiel. What do you guys think I should do? I imagine replacing an orignal would be a lil hard to do a find? Yes? No? Should I just install an aftermarket one? I like keepin her orignal but it's not the most important thing on my list. I don't really plan on selling it so I'm not freaked out to bad about losing a lil value cause of an aftermarket antenna. Thanks
brian
Old 06-06-2004, 04:48 PM
Get the FUBA roof top antenna. That's what I had planned on doing with the later front end group I was going to use on the 83 -- no fender antenna cut out.
Old 06-06-2004, 05:51 PM
