Clutch is out (LOOK AT THIS)
I think I figured out why my release bearing was getting kinda noisy.
The pressure plate is BROKEN. Two cracks and the bearing side got all crooked and jacked the bearing. Look at that damn thing. Can you imagine how that bearing was spinning???
Shane
1987 944S
2000 passat 1.8T wagon
Old 06-06-2004, 06:52 AM
AFJuvat's Avatar
Which would also explain why the fork shaft was hard to get out.
Now, look VERY carefully at your clutch fork - look for odd wear or cracks - if it is too far out of whack, you will need to replace it.
AFJuvat
Es geht nicht darum wie schnell man faehrt, sondern wie gut man schnell fahren kann.
Ihr Brunnen der nutzlosen Porsche Information
Old 06-06-2004, 06:54 AM
Ever seen anything like that. I can't figure out what would have done that??
1987 944S
Old 06-06-2004, 06:57 AM
ae1969's Avatar
Send a message via ICQ to ae1969
Old age and fatigue.
I have seen broken splines..... but definitely not too common.
That explains the trouble of pulling the shaft out..... You will probably find that the clutch fork bearings have seized and worn a nice groove into the shaft as well....
Replace everything.
Alex - PCA Polar Region - Boxster Muncher
86' 944 Turbo - Megasquirt - 326 rwhp/340lbft @ 18 psi SOLD
www.edmontonhomelife.com
www.edmontonrealestate.ws
Old 06-06-2004, 08:41 AM
going to take a good look at it today. When I took it out it looked good though. I think it only drove about <1000km with the noisy bearing. I will be giving everything a good cleaning today so we will see.
1987 944S
Old 06-06-2004, 09:38 AM
So, I guess I can't re-use the pressure plate huh? Just joking. I already have a new one.
1987 944S
Old 06-06-2004, 09:39 AM
Burn the fire.
Brando's Avatar
Haha... just a couple visits with a MIG welder
[x] Working | [_] Broken: 2017 Victory Octane
[x] Working | [_] Broken: 2005 Ram 1500 SLT w/5.7L Hemi
"Drive it like you stole it."
Old 06-06-2004, 11:55 AM
Damn, I don't have a mig welder so I guess I am just going to have to use this brand new sachs one I have sitting around.
Just cleaned everything and painted my exhaust. I looked at the lever and it looks good. I punched out the bearings and I am going to replace those just to be sure. Shaft is perfect so it should be fine.
1987 944S
Old 06-06-2004, 01:42 PM
Burn the fire.
Brando's Avatar
Rock on. good work, too. I'm amazed to see one fractured like that
Old 06-06-2004, 01:57 PM
todwic's Avatar
Send a message via AIM to todwic Send a message via Yahoo to todwic
Just throw some JB Weld on it. After you boil it, of course. You can use a sock to dampen the vibration.
*Disclaimer: The person above is actually dumber than he appears.
my web site Torque values maintainance and repairs lots of my rebuild pics weights and measurements
'84 944 auto/ps/ac/cc
'86 951
Providing ignorance one post at a time.
Old 06-06-2004, 02:29 PM
Can I not just push a sock throught the bearing and attach it to a door. Then if I slam the door it should all go right back into spec. If that goes ok then I may just reverse the slave cylinder and get it pulling on the sock thereby pulling on the bearing. Hydraulic / fabric clutch. Easy as pie.
1987 944S
Old 06-06-2004, 04:20 PM
todwic's Avatar
Brilliant!
'86 951
Old 06-06-2004, 04:51 PM
Burn the fire.
Brando's Avatar
Inconcievable!
Old 06-06-2004, 06:28 PM
