-   -   CD Install (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/166514-cd-install.html)
DARKiGOD 06-06-2004 02:33 PM
CD Install
Hello all.
Trying to install a stereoo into my early 1985 944.
The retard that owned the car before didnt take care of the car at all and tore the factory wiring harness out of the car.
Got most of the wiring figured out, one little thing, i need an ACCESORY wire, a 12v wire that is turns on with the ignition. Any ideas of a wire that would be behind the dash close to the A/C controls where the cd player will be going for this purpose?
THANKS FOR THE HELP
Brando 06-06-2004 02:55 PM
If he tore out the factory harness, you'll be looking for a yellow or red wire that comes off of the ignition switch (still supplies voltage in the 'off' position of the ignition switch for accessories). If he tore that out, look for (part) of one. This is assuming the relays for the stereo have been torn out.
rammstein 06-06-2004 03:09 PM
Yup- I'm pretty sure you are looking for a yellow wire.
ernestedward 06-06-2004 03:33 PM
Agreed on what you're looking for - don't remember the color. If I recall, installing my Alpine, the turn-on lead was the larger power wire, and the constant 12v was the smaller one..They both ran in the same harness with a brown ground. You'll know once you get it plugged in if you've got it right - when you put the key in the ignition (not turn it, just put it in) the cd player should come on. If not, then switch them. You won't hurt the cd player either way.
Copyright 2020 Pelican Parts, LLC - Posts may be archived for display on the Pelican Parts Website
