Oil Pressure Gauge Problem
It's a 1988 944 NA. The oil pressure gauge now stays at the maximum all the time. The car drives OK.
Any idea and tips about what to check and fix?
Ted
Ted Wu
1988 944NA, 5 Speed
Old 06-07-2004, 03:48 AM
AFJuvat's Avatar
CHeck the wiring at the oil pressure sender (it is right under the oil filter)
If the wiring is OK, you will probably have to replace the sender
AFJuvat
Es geht nicht darum wie schnell man faehrt, sondern wie gut man schnell fahren kann.
Ihr Brunnen der nutzlosen Porsche Information
Old 06-07-2004, 04:40 AM
Any specifics about checking the wiring? For example, voltage
or resistance measurement on certain wires?
Is there any way to check if the oil pressure sender is still good?
Ted
AFJuvat
Ted Wu
1988 944NA, 5 Speed
Old 06-08-2004, 10:21 AM
Unplug one wire from the sender. Turn your ignition on (don't bother starting the car). See what it does. Ground the wire to the frame. See what it does. Do the same with the other wire (one is for the idiot light, one is for the guage). If there is no difference then you have a bad wire. If there is a definite difference you have a bad sending unit (common). If I remember correctly with the guage wire ungrounded (i think it is blue) the gauge pins out. Grounded it goes to zero.
Old 06-08-2004, 01:15 PM
