Does this rocker line serve a purpose?
When modifying the 944 rocker panels does this seam serve a purpose or is it just where the front fender can be removed?
http://forums.pelicanparts.com/uploa...1086718264.jpg |
Front fender.
If I fill it when doing the 968 rocker thing it is no big deal then?
I will assume yes....Thanks. |
Filling it will not let you take the fenders off. Also the fenders move independen of the body so most likely any "fill" (bondo) will crack.
He could weld them, no?
Welding will burn the galvanizing off. Will start rusting real bad then.
Interesting.
The fenders need some movement of their own..... ..... I was thinking about masking off the 968 area and just spraying more texture coat then paint followed by clear. Just to build it up a little. Welding never entered my mind BUT, there are ways to clean and prep to avoid rust post weld. Just more extensive than I want to get into. I will have to consider this more methinks. |
| All times are GMT -8. The time now is 12:43 AM. |
