MrPants's Avatar
horn doesnt work: horn or electrical?
Apparently i need the horn to pass inspection, never heard of that before.
anyways, mine doesnt work. i put in a new fuse and checked the wire behind the steering wheel panel (it was attached).
So is there a way to test the horns? i removed them, if i just hook them up to the battery will they explode or anything?
Also, how does the horn swith work? i dont uderstand what that one wire does. could i check for voltage between the wire and the metla of the steering wheel?
84 944 Non Alcoholic
Old 06-08-2004, 05:10 PM
MrPants's Avatar
Thanks Wilk
I tightened up all the electrical connections and it is working now. It appears that the three buttons on the wheel cover were just a little worn down
Old 06-08-2004, 06:12 PM
Eli K's Avatar
FR WILK thanks a million for that post. My horn hasn't worked since I got the car, I even went as far as rigging my own ground wire, but it made the car honk on it's own each time I turn the steering wheel. All it took was tightning up that damn brown wire!!!!
Old 06-08-2004, 07:41 PM
SoCal Driver's Avatar
Grounds! Grounds!
Why is it always the grounds!!!
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 06-08-2004, 07:55 PM
MrPants's Avatar
Originally posted by FR Wilk
Tell us about the groundhog picture. Does this happen a lot in Texas?
Not as much as id like
I do beleive it was an african groundhog which should be good for another 30 hp in an acura.
Old 06-09-2004, 10:49 PM
