gt350mike's Avatar
Red face Wacky Fuel Injectors
Help me figure this out.....My son's car has been sitting for several months and we could not get it to start. I finally got the time to pull the fuel injector rail off and spin the motor and observe which injectors were working. The first time I did this, only two worked so I swapped them around a few more times and I got three to work (the problem wasn't with the DME).
I took the bad injector and hooked up to a high pressure hose (with carb cleaner inside) and used a battery charger to "power" the injectors off/on. Since I had this jerry-rigging contraption operational, I cleaned the other three. During all of this, I never saw any trash or foul colored stuff coming out.
I put everything back together and now all four injectors are working. What puzzles me is that I tried to clean them with carb cleaner earlier (just sprayed out of the can) and I never saw any trash.
What's the deal????? Other than saving myself $50, what happened?
BTW, It's RUNNING! Now I just need to find were the oil is leaking and fix the clip on the heater control box and we can enjoy this car, finally!
2015 GLK (Momma's ride)
2016 F-250
2001 BMW M5
65 CSX 427 Roadster
Old 06-08-2004, 06:33 PM
AFJuvat's Avatar
The old fuel varnished up the injector, sticking it, pressure, solvent and voltage popped the injector open again
AFJuvat
Es geht nicht darum wie schnell man faehrt, sondern wie gut man schnell fahren kann.
Ihr Brunnen der nutzlosen Porsche Information
Old 06-08-2004, 07:29 PM
SoCal Driver's Avatar
Didn't you replace the injectors with after market units?
By the way you want to back flush the injectors to clear the screens on the inlets. Just a two foot hose filled with solvent and some shop air. The pressure will force the pintal open against the return spring.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 06-08-2004, 08:04 PM
gt350mike's Avatar
We were not sure if the problem was the injectors or the DME so we held off on buying new injectors. I was going to send the injectors to have them rebuilt (just kidding, cleaned) but after finding the post on how to clean your own, we did that instead. It makes sense now that the most of the problem was varnish build-up. I should have taken a pic of our rig; we hooked up the battery charger to a household light switch along with two wires with alligator clips on the end. We toggled the switch to "simulate" the firing of the injectors.
Don't laugh...... it saved us $50 and it worked!
2016 F-250
2001 BMW M5
65 CSX 427 Roadster
Old 06-09-2004, 03:46 AM
